Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark x 3350 all-in-one
My printer will not feed paper. I tried to see if there is any panels that can open, to look inside, there is none.
I can not find any paper jams or obstacles. I tried al the trouble shoots.
What can I do?
Joe (South Africa)
  • 1 more comment
  • joyce116 Oct 17, 2008
    paper is feeding incorrectly (pulling down at 1 side) and then jamming please help
  • ddale88 Oct 20, 2008
    I have a Lexmark X1245 All-In-One InkJet Printer and I am having the same problem. Paper not feeding right, paper goes to one side and will feed through printer.
    I am having the same problem, paper is feeding incorrectly (pulling down at 1 side) and then jamming . I have a Lexmark X1245 All-in-one inkjet printer.
    Problem Solver:
  • 8 Answers
I turned mine off at the mains and put my hand down weep inside to have a feel about ........ found a small bouncy ball that my kids had lost the week before !!! Once removed all ok again ;)
Posted on Dec 29, 2008
I picked up a used Lexmark 3500 with the same problem. Had requested help fixing.
Tried to feed more paper through - still pulling hard on the right side. Tried to feed several pieces of paper - one at a time, getting them jammed then pulling them back out. Finally one got jammed way down in there - yanked it back out. Open the top(as to load ink cartridges) Saw a tiny piece of paper sticking out between the plastic rollers, got a small crochet hook (tweezers would have worked), grabbed a hold of it and pulled it out enough to get a good hold of it, then pulled it out. There had been a shread of paper jammed in the roller area. 3" long by from 1/4" to 1 1/2" wide.
My problem was the chunk of paper stuck in the roller mechanism where you could not see it or get to it, until it was partially forced out.
Hope this helps someone else!
Posted on Nov 01, 2008
Hello. I have a Lexmark x4650 printer/scanner/copier and the paper starts to feed thru and then pulls to one side. I am then unable to print my document. Why does this keep happening and how can i solve...
Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects that might have accidentally fell into it. If feeder is clear, open the printer cover and remove the cartridges. While the printer cover is open, check inside for any obstructions in the paper path. If none, then close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Close the cover. Load some paper (avoid overloading). Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jun 21, 2011 | Lexmark X4650 InkJet Printer
Paper jam
it is needing a hard reset sir.
nothing big
Apr 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
@my Lexmark says there is a paper jam but I find no paper anywhere!!?????
There could be some sort of foreign object that accidentally fell into the paper feed system. Remove the sheets of paper from the feeder. Grab a flashlight and take a look into the feeder for any debris. If you're willing and capable, carefully turn the printer upside down. Any foreign objects in the feeder should just freely roll out from it. If none, open the cartridge area and remove the cartridges. Check inside for any foreign objects that could cause this problem. If none, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on and looks for the cartridges, reinsert it. Load some paper. Try to print again. If problem continues, it could be a possible hardware problem. Please contact Lexmark technical support for additional assistance.
Apr 05, 2011 | Lexmark X2600 InkJet Printer
Hi, My Lexmark 2350 is not feeding paper through. It pulls on the right hand side but doesn't feed through and then says there's not paper in the tray. Any suggestions? Karla
Try to remove the sheets of paper from the feeder. Grab a flashlight and take a look into the feeder for any foreign objects that might have accidentally fallen into it. If none, unplug and replug your printer into your power source to reset it. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Mar 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
My printer will not feed the paper properly. It
There must be a jam on the left side then. Open and look inside for the paper issue
Jun 16, 2010 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark 5400 printer, paper not feeding, help
You can try the following. Remove all paper from the printer and turn printer off. Try opening the printer as if you were to remove the ink cartridges and check for any paper jammed in the printer. If there is a paper jammed try to remove it. if there is no paper jammed in the printer then try the following remove all paper from the feeder and flip the printer upside down and shake it a little. Sometimes things will fell inside of the paper feeder and will block the paper path thus causing the printer not to be able to pull the paper.
Jan 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 printer says, "Clear paper jam, then press check mark."
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark e320 thumping on feed
The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
5. Adjust the paper feeder guide to the sheet size.
6. Disconnect the printer power cord as well as the printer cable form the printer.
7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
10. Try printing with having only one sheet in the feeder and check if it does work.
Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Lexmark E320 Laser Printer
Lexmark X1270 All-In-One InkJet Printer Logo
218 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
