Hi
As the title says every time I put a disc in, it says 'reading' then returns to 'open tray'. I'm sending it to ms for repairs if I can't fix it myself
same problem, so i put in a game never played before and the same thing happened. it wont read the disc but i feel if i hit it with my baseball bat it might help.(haha) can somebody please email me at [email protected] with a serious solution. thank you same problem, so i put in a game never played before and the same thing happened. it wont read the disc but i feel if i hit it with my baseball bat it might help.(haha) can somebody please email me at [email protected] with a serious solution. thank you
AnonymousFeb 26, 2009
My sister put in Kung fu Panda and it wouldn't read now the xbox won't read any other disks and says reading on the menu and then says open tray.My sister put in Kung fu Panda and it wouldn't read now the xbox won't read any other disks and says reading on the menu and then says open tray.
AnonymousMar 28, 2009
this is really pissing me off... i've looked all over the internet and can't find how to fix it, anything i've looked at on youtube or anywhere else doesn't even work. i just got off grounding and got my xbox back and now this happens? not only that but while i was gone one night someone spent all my ms points... someone please help... i need a solution, and it's not the disk. this is really pissing me off... i've looked all over the internet and can't find how to fix it, anything i've looked at on youtube or anywhere else doesn't even work. i just got off grounding and got my xbox back and now this happens? not only that but while i was gone one night someone spent all my ms points... someone please help... i need a solution, and it's not the disk.
Yea exact same happened me before and it just worked by fluke.. and now this mornin its happenin again bt i cant get it t work! its soo annoying!! can anyone help? il b damned if im sendin my xbox away for 3 weeks.. x
AnonymousApr 16, 2009
All the same and a base ball bat might work... but i was thinking more along the lines of hihg explosives (hehehehehe :)) that might do the trick
AnonymousApr 28, 2009
yeah my xbox 360 does the same!! wtf ! i dont want to send it in =( whats the problem!! D: email me at [email protected] if you have some solution yeah my xbox 360 does the same!! wtf ! i dont want to send it in =( whats the problem!! D: email me at [email protected] if you have some solution
You can't post conmments that contain an email address.
I found a solution that works for me after a long period of time with
this problem.
Get an air spray canister (just compressed air),
open your Xbox's game tray, take the disc out, then spray the air along
the tray, moving side to side inside the Xbox. You may want to spray
into the vents, too, just to be sure.
This worked for me, and it
was the only thing that worked for me. I had already tried hitting the
console with the controller (gently), and doing the stuff Microsoft
recommends etc.
If that doesn't work, you could try gently
knocking the top of the Xbox with your conroller, when you put the disc
in, as I've heard that works for some people.
Another thing that
works for some people is taking the disc out, closing the tray, then
when it goes to Open Tray, open the tray, put the disc back in and then
closing the tray again.
this problem.
recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email [email protected] for a pricing for repair. http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
1, the disc may be dirty 2. the mian reason for this your xbox drive
cannot read the disc , because the power of the lens is gone(not
completely) ,
solution:
1. keep your disc inside the drive
and switch off the console, again swith on try this 2 to 3 time 2.
keep the console in vertical position or little slanding position(180
dg) make sure it does not fall
3. its better to buy hatddisc and
load the game inside it , so that u lens life increased
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive. Please vote for me.
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
when loading disk it says reading then it says open tray
i have the same problem xbox 360 i load disk says "reading" and goes back to "open tray" hope someone can help!!! thanx
Ya same here, and it is not a dirty disc problem. I tried all my games, some DVDs too. It just won't read.
its soo annoying!!
can anyone help?
x
