Question about Magnum 257 CB Radio
Magnum s-980 freq. counter is turnd of when noise blankers are on full.
  • road69 Oct 20, 2008
    I am awaire ove this but whould like to chang it....
    fixed the problem... clip the small brown wire on th right side of the blanker swich . the counter will stay on now.........
All the s9 do this its not a fault
Posted on Oct 20, 2008
Freq. display not correct but radio is on the write freq.
This of no surprise because it is just that a display not a counter.
There must be an alignment pot for the meter display although there will be some doubt if you just align it with out using a frequency counter.
http://cbtricks.com/radios/rflimited/index.htm
you might find more alignment info under the S45 omegaforce as they have similar boards.
hope this helps...goodluck!!!!
Aug 06, 2011 | Magnum 257 CB Radio
Hi my deltaforce is slightly off on ssb you have to be on 27554 and clarifier at 12 30 to be spot on 27555 thanks vince
Use a known good external freq counter, and do the tx alignment. that will put your meter back on showing the right freq when you are..
Jan 27, 2011 | Magnum DeltaForce CB Radio
TS-450S Noise Blanker, No 1 & No 2 neither has any effect on noise
The noise blanker settings on the TS-450S (and S/AT) are true noise blankers and should not be thought of as a DSP device or something that they are not, like a notch filter or IF shift and etc. They will do a fine job of eliminating ignition noise as well as eliminating the electric mixer or blender noise from the kitchen...... however they will not remove static crashes or quieten those atmospheric noises on 75 meters during summer time thunderstorm season activity.
Hope this helps!
Apr 15, 2009 | Radio Communications
NB-ANL buttons what are there funtion?
NB-Noise blanker this helps elemenate noise in the receive.ANL-Automatic noise limiter wich does about the same thing as the Noise blanker.
Nov 06, 2008 | Cobra 29 LTD CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Magnum S9 10/11 mtr radio
If you're receiving OK on AM & SSB, the likely adjustment would be the FM discriminator coil L5. You can adjust it for maximum noise with no signal applied.
Mar 22, 2008 | Magnum DeltaForce CB Radio
Magnum 257 off freq
Colin, here is all the tech info on alignments that your looking for,,,go here;
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Hope this gets you on the right track,, let us know.
Mechanic
Mar 09, 2008 | Magnum 257 CB Radio
Delta force magnum radio
Herman, one thing that should help is turn on the NB and also TONE .
Feb 08, 2008 | Magnum DeltaForce CB Radio
Radio Communications Logo
112 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
