Question about Sony Cyber-Shot DSC-F717 Digital Camera
Dsc-f717 after a battery change camera cannot turn on.
Changed the battery then switched cam on... "on" light flashed on for split second then off. repeated attempts with other batteries gave same result or a "nothing" response from camera
could it be a problem with an internal battery (isn't there one that remembers date, time etc?)
one person wondered if the flash of the "on" light might signal some kind of override....
  • Anonymous Mar 07, 2009
    unable to turn on camera, even with charger plugged in
  • Anonymous Mar 21, 2009
    X2
    But some times my works a few second then turn off again :S
    Put a new battey and problem still continuos
I have the same problem. I recharged batter but when I try to turn on my DSC F717 he just want start. Sometimes you just have to wait few hours and then its possible to turn it on. It is becoming very annoying! Any answer would be very helpful.
Thanks!!!
Posted on Jun 12, 2011
Built in flash on Sony DSC-F717 will not open up. Have reset and checked all settings.
BAD battery !!The high quality Rechargeable Sony Cyber-shot DSC-F717 Battery [Non-OEM], It can provide extended power for your Sony Cyber-shot DSC-F717 digital camera, this battery is made specifically for your digital camera and to meet or exceed the original manufacturer specifications, we will ensure optimum performance saving you time and money.
Sep 04, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Camera completely dead. charge light doesn't come either
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 08, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony cybershot f717 battery won't charge
Same for me too... And a bunch of other stuff! I can't choose to have the flash, can't use the veiwfinder...
Oct 11, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Hope it will solve your problem....
Oct 06, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Flash doesn't work
The fault may be a simple setting that may have been changed, have you checked your Manual to see if you can disable the flash? Is the flash disabled?
If no, take it to a Camera Repair shop (can be sent through any Camera Retailer) and get a quote to fix it, then decide whether it is economical to fix or better to buy another camera.
Note: this is still a "good" camera for it's features, so don't rush out and buy another camera unless you really want to.
Good luck.
Apr 13, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
DSC-F717 won't turn on
You are correct. The battery has lost it`s life.
Contact your nearest Sony dealer and ask them for the NP-F50 battery which I think your camera uses.
The reason why the battery still shows it is charging ( if your interested ) is due to the sensing cct - you will see your battery has three poles and not just 2. The sensing pin is faulty due to the buildt in PCB having a problem. The batteries probably are still ok inside, but the sensing cct does the actual charge control.
Best of luck.
Mar 05, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony DSC-W50
1. Turn OFF cam
Dec 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
DSC-F717 error messeage
Try and clean the contacts at the memory stick slot by using a contact cleaning solution. The solution should be available with any Philips service dealer or PC shops.
Nov 20, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot DSC-F717 5.0 Megapixel
Hi Bella
That code means that the lens unit was unable to move from home position to switch on position.
These lens are extremely complex and I doubt if you could find someone able to repair the lens.
Therefore I suggest contacting Sony to find a accredited dealer to quote you on replacement of the lens.
My guess is it will cost half of what you originally paid for the camera.
Good luck.
Sep 06, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
62 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
