Question about Scytek 2000RS Remote Control
Remote start relearn after removal and install in another vehicle.
Curious if anyone could tell me how to put the module(galaxy 5000 5000rs) into relearn of crank signal input. removed remote from pontiac grand prix 6 cyl. now in 96 suburban 8 cylinder. remote starts but tuns for few seconds and then shuts down. apparently due to tach input pulses different between engines. Any help?
    Problem Solver:
  • 13 Answers
Turn key on. within 5 seconds press switch 5 times the siren or horn will sound,then push switch 21 times and hit button 2 on remote then turn key off .this sets to gas engine.then start car do the same thing but press button 1 led should light and stay on if this is a good tach wire.did you get the take wire at ecm on drivers side inner fender black plug with white wire or did you just tap a fuel injector wire
Posted on Oct 20, 2008
Where is the body control module located on a 2001 ford explorer
In this model year Ford calls the BCM- Generic Electronic Module (GEM) It is located , Behind center of I/P !
Module - Generic Electronic (GEM)/Central Timer (CTM) Removal
  1. syn~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
    Depower the supplemental restraint system (SRS). For additional information, refer to Section 501-20B .
  1. Remove the audio unit. For additional information, refer to Section 415-01 .
  1. Remove the center instrument panel finish panel.
    1. Remove the screws.
    • Disconnect the electrical connectors.
Remove the GEM/CTM.
  1. Remove the screw.
  1. Disconnect the four connectors from the GEM/CTM.
  1. Remove the GEM/CTM.
  • Installation
    1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
      To install, reverse the removal procedure
    May 16, 2016 | Ford Cars & Trucks
    We're is the bcm location on 98 Ford explore 4.0 v.6 sport edition
    The module on this truck year is called a "GEM", BCM comes later. The GEM is located behind the radio assembly and is bolted to the IP support bracket, it has 3 large connectors. See photo below.
    The following is from Alldata:
    >>Prior to removal of module, it is necessary to upload module configuration information to New Generation STAR (NGS) Tester. This information needs to be downloaded into the new module once installed.
    Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result<<
    then after install:
    >>To install, reverse the removal procedure. CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the New Generation STAR (NGS) Tester into the new module. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
    Feb 22, 2016 | Ford Cars & Trucks
    I did remove the battery when I connect it back the car does start but not iddling
    What year make and model of vehicle? In some cases, when the battery is disconnected/removed, the vehicle will need an idle relearn procedure. This can usually be accomplished by keeping the vehicle running with your foot on the gas pedal and gently revving the engine til idle will stay by itself. It is then a good idea to drive the vehicle for any other module relearn that may be necessary. In some cases, the relearn procedure must be accomplished using a scan tool.
    Jun 21, 2015 | Cars & Trucks
    GMC Envoy relearn procedure
    The modules need to relearn the conditions it operates under. Take both battery cables off and touch them together for several minutes. Reconnect and start the engine. Drive the vehicle 20 or more miles in city traffic. That will relearn the modules.
    May 25, 2014 | 2008 GMC Envoy
    I need 02 ford to relearn code in as-tcbm, getting incorrect key code error in theft module, i have no manual for as-tcbm
    there is a factory ford key in the astcbm. I doubt it needs to be relearned most likely a connection issue,or the ring from the astcbm isnt mounted correctly.
    Jul 29, 2011 | ASTCBM Generic Factory Remote Start ByPass...
    I recently had an avital 4103 remote start system installed in my 09 Chevy Silverado truck. The remote starts the truck perfectly everytime however the lock and unlock buttons dont unlock or lock everytime...
    As an L1 ASE Master tech I ALWAYS advise against aftermarket alarm systems, however the problem you are experiencing is due to an action that is not being taken by the vehicles control modules. The installer should tie into the door control modules or find out why the body control module is recognizing the command for the locking/un-locking action, (hence the lighting response), but the doors are not taking appropriate action. I would have to look at live data in the vehicles control modules to see what modules are being commanded to do what. Take it back to the place where it was put in and tell them to fix it or refund it.
    Nov 21, 2017 | 4103LX Remote Start System with Two...
    Locate lcm module 98 lincolin wont stay on
    LCM is usually under dash above driver's feet.
    They are $400. Gino on ebay fixes them a lot cheaper. Just search for lighting control module and you will find him.
    SECTION 419-10: Multi-Function Electronic Control Modules 1998 Town Car Workshop Manual
    REMOVAL AND INSTALLATION Module -Lighting Control (LCM) Removal
    1. swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of module, it is necessary to upload module configuration information to New Generation STAR (NGS) Tester. This information needs to be downloaded into the new module once installed.
      swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
      Disconnect the battery ground cable.
    1. Remove the LH instrument panel lower insulator.
      1. Remove the pin-type retainers.
      1. Disconnect the courtesy lamp.
      1. Remove the LH instrument panel insulator.
    1. Position the LCM aside.
      1. Release the locking tab.
    1. Remove the LCM.
      1. Disconnect the electrical connectors.
      1. Remove the LCM.
    Installation
    1. swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the new module is installed, it is necessary to download the module configuration information from New Generation STAR (NGS) Tester into the new module.
      NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns it adaptive strategy. The vehicle may need to be drive 16 km (10 miles) or more to relearn the strategy.
    Oct 30, 2010 | 1998 Lincoln Town Car
    How do you reprogram (reset) the remote starter after power has been disconnected? I dont know what model
    Most remote starters do not lose their "memory" when power is lost. However, if an older version bypass module was used for your vehicle it may need to be reset but you must know the model. If you are not able to look under the dash panels yourself, you should take it to your nearest dealer/installer. Some also reset or relearn after the first key start. The FCC number off of one remote may help narrow down model of the remote start also. Vehicle info will also be helpful. DC
    Nov 04, 2009 | Omega MARS-22 Remote Vehicle Starter with...
    I need a printable diagram for replacing an altenater on a 1994 ford mini-van. Does anyone know a website to find one for free?
    Removal
    1. Disconnect battery ground cable (14301) .
    1. Remove snow/ice shield.
    1. Remove engine air cleaner intake tube (9A624) .
    1. Disconnect the generator voltage regulator wiring (14305) to the voltage regulator.
    1. Remove wiring connector bracket.
    1. Loosen the drive belt tensioner (6B209) and remove the drive belt .
    1. Remove the bolts holding the voltage regulator to the generator bracket (10A313) .
    1. Remove the voltage regulator from the generator bracket .
    Installation
    1. Position the voltage regulator on the generator bracket .
    1. Install the bolts and tighten to 40-55 Nm (30-40 ft-lb).
    1. Install the drive belt over the generator pulley .
    1. Adjust the drive belt tensioner as outlined in Section 03-05 .
    1. Connect generator voltage regulator wiring to the voltage regulator. Tighten generator Battery Positive Voltage (B+) wire attaching nut to 9-12 Nm (6.5-9 ft-lb).
    1. Install wiring connector bracket.
    1. Install engine air cleaner intake tube .
    1. Install snow/ice shield. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more for powertrain control module to relearn the strategy.
    1. Connect battery ground cable .
    Jul 28, 2009 | Ford Aerostar Cars & Trucks
    Python 1400XP remote start system
    yes you are correct the learn procedure is done by a dei 555L or a 555G bypass module.your car should have one or the other installed on it. simply unplug it,it will be a three wire plug. then plug it back in and then by turning the ignition on and off it will relearn the code.
    Dec 05, 2008 | DEI Python 1400XP Remote Start/Keyless...
    Scytek 2000RS Remote Control Logo
    534 people viewed this question
    Top Scytek Televison & Video Experts
    Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
