Question about Acer Computers & Internet
Need to open acer aspire 3620 to replace fan
Need to replace fan
  • gwenbradleya Oct 17, 2008
    Hi, thanks for the answer, but i believe you have to end up going through the top, and removing the MB to get to the fan. I believe the bottom is one whole piece, thanks, GB
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    it might be accessible from the bottom..check for screws holding a plate with louvers in it..
  • Acer Master
  • 4,338 Answers
I believe that the 4020 and 3620 have the same chassis. See if this helps
To the left of the battery there is an I/O cover with 2 screws, then the heat sink cover has 2 screws. There you should see the Thermal Unit (fan). It has 4 screws. Take those out and lift the unit out.
Let me know , curious to see if they are indeed the same chassis.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 16, 2008
  • JDTec
    JDTec Oct 17, 2008
    I just found a illustration of the bottom of your laptop, The fan appears to be on the bottom of the system board.
    I could not find a free service manual, you can purchase one at these sites.:
    http://www.9manuals.com/acer_sm.htm#aspi...
    http://www.electronicsrepair.net/comp2ac...
    You may have to copy and paste the link into your browser.
    Thanks, Joe
Acer aspire 3620 window problem..bios password forgot how to install new window
mmm for me the best solution is reinstall de windows, to recuperate the password is so hard.
Oct 11, 2010 | Acer Aspire 3680 Notebook
My Acer Aspire 3620 crashed. I reloaded my
How did you access this website if your modem is not working?
Jun 17, 2009 | Acer Aspire 3100-1405 Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Prolem with acer 3620
Try a new memory stick initially, Only 1 if the cost is high and see if it does boot up correctly. If not then you probably have had a surge or lightning damage and may need a new power supply. Just try the memory stick fist then go from there.
Apr 17, 2009 | Acer Aspire 3610 Notebook
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
Component missing Acer aspire 3620
Hey,
The vga board on this laptop heats up very easyly and the heatsink is uselessly small. Video may fail withing 12 months. I would recommend another laptop model, this series 3xxx and 15xx have cooling issues and parts fail often. Not much you can do about the problem.
Thanks,
Ekse
Aug 19, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3620
I hope this helps:
This first link is for windows vista, if thats what you are running
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-3620-Bluetooth-Driver-601.shtml
now the this one is for windows xp: click the link and then click the little green box on the left witht he arrows pointing down.
http://www.notebook-drivers.com/ViewDownloadUrl.asp?ID=87869&brNum=3&show=0
Jan 21, 2008 | Computers & Internet
Computers & Internet Logo
670 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
