Question about GE Kitchen Ranges
I have a GE oven, when useing the regular oven how can you lower the temperature after setting it?
  • 1,543 Answers
Push clear / off. Then bake and new temp.
Posted on Oct 16, 2008
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
How is the china and crystal wash cycle different from the regular cycle on my GE Triton XL dishwasher? Can I use regular dishwasher soap on my china and crystal?
Most dishwashers that employ this setting use a lower temperature for the water and also they do not use the element to dry the dishes, they are air dried. China and crystal are very sensitive to changes in temperature and can crack easily. They should always be washed by hand however if you have to use the dishwasher make sure you have a mild detergent. No bleach or acid should be contained. If it says citrus anything it has acid in it. Also use half the amount of detergent regardless of its strength. Hope this helps. Good Luck!
Jul 19, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
I bought an oven thermometer and it indicates that the oven temperature is approximately 100 degrees lower than the temperature set on the oven. Is there an adjustment to make so the set temperature is...
It sounds as if an element in the oven is not working do check again that the oven thermometer is on same scale as the oven settings farenheit or centigrade.Most likely it is an element fault.
Hope I helped.
May 07, 2010 | GE Profile JT915 Electric Single Oven
Oven with convection - when baking cookies, cakes, etc they aren't getting done. Bottom and middle is soggy. Both coils look to be heating, convection fan is working.
Set the temperature one position higher. Convection ovens have a more even heat spread so if you used to bake at the top of your old oven it will now be slightly lower temperature
Dec 06, 2009 | GE Profile JB900BK / JB900KK / JB900TK...
Ge stove
Replace the temperature sensor inside the oven cavity. It looks like a small metal rod. Be aware you will never get an accurate temperature reading with those cheap 5 dollar things. After the oven is preheated, you must wait 10 minutes and take a reading. Some models have a temperature adjustment, it's listed in the owners manual.
Oct 28, 2008 | GE JBP69 Electric Kitchen Range
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
