Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
MDB8750AWS I had to replace my board 3 times this year. Once the board is replace the dishwasher will work for 4 months. Can you please let me know what is the problem, because changing the board is getting very expensive.
    Problem Solver:
  • 7 Answers
Do you have alot of electrical storms, install surge protectors on all electronic appliances.
was the board and the person installing the part grounded. static can make those parts fail within a few months.
Posted on Oct 16, 2008
Does anyone know if this dishwasher has an OBD on board diagnostics for being able to get error codes it is model MDB8750AWS
Under the kick plate. There is a envelope.. wrapped in a bag that you usually have to rip open. Should be in there.
Cheers
Apr 11, 2015 | Maytag Dishwasher
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code PE on Samsung dishwasher DMR78AHS
I too have the same problem with my dishwasher. Didn't know about the circuit breaker trick. Will give a try. My husband is ready to throw all our Samsung appliances in the trash. We don't recommend them at all. Re-modeled our kitchen 4 years ago and had all new Samsung appliances installed. What a mistake. In the 1st year we had 2 service calls on the dishwasher, 2 on the stove and 1 on the refrigerator. Have had many problems with the dishwasher. Have been in touch with the company but their approach is you bought it your stuck with it. Thanks for the trick to fix PE error code. I'm NOT getting it fixed. I'll use it till I can't use it anymore then go buy something else.
Aug 24, 2012 | Samsung DMR78AHS Builtin Dishwasher
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power to conrol board but nothing works changed board and panel 3 months ago
If you changed the control board and control panel then and it worked for awhile I'd sugguest you look at that first. You board should have came in a ESD bag. I worked in a factory and I know that boards are very sensitive to electro static discharge. Ex. walking on a rug and shocking a computer board. When this happens computer boards are damaged and will work for a period of time, however, they will fail eventually. When handling boards be sure to ground yourself buy touching metal on the dishwasher and then touching the board unless you have an esd cord.
Hope I was helpful please rate me a 4 if that helped
Have a super day!
Dec 10, 2010 | Maytag 24 in. MDBH950AWS Built-in...
I am recieving an SE code on my samsung dishwasher. I tried to reset the dishwasher by switching off the power to the machine for 20 minutes. still SE message
I'm getting the same message too. I turned it off for awhile and I had a technician come out and take a look. My drainage pipes are all clear (SE code can mean that drainage is not working properly). He suggested that I get a "Samsung" tech out to take a look at the circuit board/electrical issue. Want to know the crazy thing? This is my second dishwasher that Samsung replaced....all the same electrical issue.....and just last week someone called me to see if I wanted to buy an extended warranty on it. Hmmmm.....do they know that this a piece of junk? It was an expensive dishwasher too.....doesnt clean any better than my cheap model did and it sure has a lot more problems in this first year than the whole 5 years that I had my other dishwasher. Can you tell im disgruntled?
I would love to hear if there is a simple fix to this SE problem.
Sep 25, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
Touch pad/control board not working?
PART NUMER 8193762 IS WHAT YOU WANT TO CHECK. YOU CAN SEE THE PICTURE OF THE PART AT REPAIRCLINIC.COM
Apr 24, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher won't work
i think they been charging you for the control panel and replacing the fuse there is a fuse in the control panel go to appliance parts store and tell them you need control panel fuse for your model get two or three then remove the panel and replace the fuse
Sep 07, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Mdb8750aws dishwasher dead, no front pannel lights, no functions
I just fixed my washer!!! had power to control board. romoved lower panels openned connection box ( one screw) cut and cleaned wires and reconnected to power line that runs to the plug. Did it twice and finally got a good connection started right up. WAS just about to order a new circuit board. SAVED MYSELF $100.00 !!!!!
Dec 05, 2007 | Maytag 24 in. MDB8750AWS Jetclean II...
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
183 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
