Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
New black installed; will not print in black ink. Everything else prints!
I installed a new black in cartridge in the printer just as I have done before and while the color cartridge prints the black does not. Is it possible the black ink cartridge has dried out even though they both came out of the same package?
  • shopsmith Oct 23, 2008
    I did call the hotline and talked to Johnny. He led me through the performance and determined it was the printhead. Awaiting the shipment now- should be here Saturday. Thanks for all your effort.
  • Anonymous Nov 10, 2008
    I have replaced the black ink cartridge, then attempted to calibrate and the scanner would not scan.
    Problem Solver:
  • 19 Answers
Hi, it is possible that the black cart was not installed properly. Try reseating the black cart and see if it works. You can also try to calibrate the printer. you can do this by pressing the menu button then go down to calibrate printer. after that it would also help to perform a deep clean which can also be found on that same menu. then try to print. If all these fails, try to call the kodak hotline 800.421.6699
Posted on Oct 22, 2008
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
Printer does not print black ink
I have seen many NEW dried out cartridges. i would try new ones again.
Dec 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Won't print black
MY DELL 725 PRINT WILL NOT PRINT IN BLACK INK. I HAVE A NEW PRINTER. I EVEN BOUGHT A NEW INK CARTRIDGE AND IT STILL PRINTS IN GREEN ONLY. WHAT CAN I DO TO HAVE MY DOCUMENT PRINT IN BLACK?
Jan 01, 2008 | Dell 725 InkJet Printer
All colors not printing
hi this is nichu, you have done everything correct but the ink is low in your catridges refill it or purchase a new one.
Nov 20, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
