Time TV I have a Time tv - all I get is a blue screen - no sound/picture or channels. I've tried switching to TV mode - but it looks to be stuck on channel 7 - volume control/picture controls appear to work. But I can't seem to get any channels
    Scholar:
  • 86 Answers
By saying that volume and picture controls work, do you mean you can access the TV's onscreen menu? If so, you may need to re-scan for available channels if you are using the TV's internal tuner. If the memory of those channels has been lost, the TV does not know where to "look" for a signal. You may also need to perform a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. After this step, try the channel scan again if it didn't resolve the issue the first time.
Posted on Oct 17, 2008
Toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 07, 2017 | Toshiba Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
Troubleshooting tv
you need to buy tv converter box,
Jun 16, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
50" LG Plasma Screen TV does not have any sound or activity on the screen.
input correct ? eg:HDMI 1 USE MANUAL TO GET INTO SETUP MODE.go through all settings.check the contrast and brightness buttons n the TV if any on back or top.
Apr 15, 2013 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
My panasonic DMR-EZ45V will not auto -setup restart the dvb freeview channels it goes through the channel numbers but they do not download only the anologue channels download. it is connected to a...
I have one of these with the same problem. I couldn't find any others with answers but there are people giving answers about the DMR-EX75 showing the same problem due to power supply decoupling capacitor failure.
I just ordered a manual for mine from manualzone.com to try to locate the culprits. - Wish me luck!
Jul 25, 2011 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
