Question about Cooktops
Dacor SGG365 gas cooktop inop ignitor
One of the 5 ignitors does not spark when its respective control is turned on, yet does spark (and will light off) when after turning it on another one is turned on. Is this a problem with the individual ignitor or with a controller of some sort?
Mike
  • jpolk Oct 22, 2008
    I have a Dacor Preference SGM365 with the same problem. One control knob will not cause it's respective burner (or any burner) to spark. If I use another control knob, it does spark and ignite.
SOURCE: Dacor ignitor keeps clicking
an where pray do do you get such a spanner wrench???
Posted on Sep 11, 2008
  • 110 Answers
SOURCE: Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Posted on Oct 23, 2008
SOURCE: Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Posted on Jun 18, 2009
SOURCE: My daughter has a Dacor cooktop Model SGM 464 EM
I found a satisfactory answer elsewhere on the Web. Thanks.
Posted on Jan 12, 2010
heatman101
  • 43501 Answers
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
I have an amana AKS30E gas cooktop and the ignitors are sparking approximately every 30-seconds on their own. I have checked all the knobs etc and each burner lights fine but with the gas off and ignitors...
I think it's more likely to be a wiring problem, either bad ground or loose connection on the controls of the spark module connector. Look carefully at the switches on the controls to see if they are asking for spark when they're supposed to be off.
Best Regards,
bruce
www.fixyourboard.com
Jun 19, 2010 | Amana AKS3040 Gas Cooktop
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
My ignitor will not go off. The burner will light
Unplug the appliance for at least 1/2 hour and then plug it back in and see if the problem goes away. If not, you may have a defective ignition board or a bad connection somwhere.
Aug 01, 2009 | Dacor Preference SGM304 Gas Cooktop
Oct 22, 2008 | Cooktops
Dacor has updated ignitors with a broad head. Install the new ones and it will very likely cure the problem. You'll need a special spanner wrench to remove the burners. And watch out for the flying keeper clips.
Oct 06, 2007 | Dacor Preference SGM365SS Gas Cooktop
Cooktops Logo
221 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
