Question about Ovens
Oven cooking too hot
Oven temperature is over 100 degress too hot. Cooking instructions tell you to cook at 350 for 30 minutes. I will have to turn the dial to 250.
Do the older ovens have heating elements? Is this what I need to replace.
Thank You,
Charlotte
Model #628-9447313
Serial # 135851
  • 236 Answers
SOURCE: Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Posted on Jun 11, 2007
barkencoa
  • 3463 Answers
SOURCE: seems to be taking a long time to cook
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Posted on Dec 15, 2008
  • 1122 Answers
SOURCE: lower baking element has a hole in it
they get weak in some spots and do that,all you do is remove the 2 screws on the back of element pull out remove both wire jack and install new one,you can get one at sears .com,click on parts put in your model number and get your part-mike
Posted on Dec 26, 2008
barkencoa
  • 3463 Answers
SOURCE: oven tempture
The solution I am proposing here only applys to electric ovens and not micro wave ovens.
The usual reason for fluctuating oven temperatures is a faulty or out of calibration thermostat.
Some thermostats can be recalibrated, but in my experience, it is better to replace it.
Another reason for fluctuating temperatures is a badly fitting oven door, or a worn or faulty door seal, the door should be a good firm fit agaist the seal.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
  • 221 Answers
SOURCE: instructions for delay cook timer
Here's the link where you can get the owner's manual with instruction's,
http://www.maytag.com/support/manuals_literature.jsp
Posted on Apr 05, 2009
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
Is there a way to turn off the fan in the oven, and still use the oven to cook? My oven is far too fierce.
Unless your fan oven specifically has a control to turn off the fan, then the answer is "no". Disabling the fan will cause the element to overheat and fail.
Fan ovens are far more efficient for most types of cooking, but you have to adapt by using either shorter cooking times, lower temperatures or both. Many ready meals have separate fan oven instructions for this exact reason and you can search the web and buy books for recipes and methods specifically aimed at fan oven users. Once you're used to fan cooking you'll hate using regular ovens again.
I hope that you have found my answer to be of use and ask only that you return the favour by rating my answer.
Oct 24, 2009 | Ovens
Oven overheating
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
Sep 20, 2009 | Fisher and Paykel AeroTech - OS302M...
Gets hot too quickly food cooks too quickly
no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Seems to be taking a long time to cook
thanks.
Dec 14, 2008 | Ovens
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Cooking
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Feb 07, 2008 | Blodgett DFG-100 Gas Single Oven
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
