FixYa.com
Tags:
IBM FAST500  Transceiver
NSS Abends on one SAN adapter only.
By Powe33 - usenet poster
All
I have a FASTt500 SAN / QLogic 2200 configuration on a 3 node Netware
51sp4 cluster SP3.
Both IBM SAN adapters advertise 20 MB unknown media thru NWConfig/NSS Disk
Options / Modify Partitions and Hot Fix. The 20MB media is on LUN 31.
All real disk media is configured on LUNS 0-7
All NCS nodes believe Adapter A has 20MB Free Space and Adpater B has a
20MB NSS partition.
My problem is that when NSS loads, the MBMMPRV module ABENDS the server if
Adapter B is loaded (i.e. QLogic 2200 is loaded re-entrantly to support
both Adapters to provide failover). MBMMPRV obviously dislikes this 20MB
NSS partition.
I cannot delete the 20MB NSS partition using NWCONFIG. The server ABENDS
if I try to do so.
Any suggestions on how to deal with this would be most appreciated.
Andrew
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 28, 2006
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Andrew,
You may already know about this, but just in case you don't:
If you have two adapters you need the IBMSAN.CDM module. You also need some
additional parameters on the QL2200.HAM load line, detailed in section 2.0 -
How to install the driver" in the following README file:
Note:
- The IBMSAN.CDM driver is for redundant FC-HAs ONLY, and should not be
loaded if you only have one adapter. You'll get some strange situations in
the cluster if you do and you try to pull the FC cable...
RagS!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
Thanks for thinking about this one. I'll try give you some more info.
The Mirrored Cluster Partitions are on LUNS 6 and 7 on two dedicated
logical disks. They are both 15MB in size and appear healthy.
All BIOS / Firmware has been implemented.
QLogic cards are at 1.76 and the HAM is at 6.50p (IBM rev)
The 20MB of media is on LUN 31 which IS the adapter, not any attached
storage media. All attached storage media is on LUN 0-7.
Any ideas?
Regards
Andrew
I'm not sure what the problem is with the Qlogic 2200's is, I have
Solution #3
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
only used a Fast500 and QL2200 with NW6.
The 20 MB is the system partition for the cluster. This should be
left alone, if you delete it you can kiss goodbye to your cluster!
There are some TID's on the switches for the QLogic cards that help
with the path routing. IBM has also published a document on the
QL2200 settings that you should make when setting up the system. They
also have Bios updates for the QL2200 which made a massive difference
with the NW6 system that I set up.
Tim
Scotland
God's Country
Volunteer SYSOP
No Direct Mail Please.
Can you Help with these Transceivers problems?
Transceivers
required,mic wiring details for...
ft 290 wiring details for mic. Answer This...
Transceivers
mic wiring details reqyuired...
yeasu ft 290 mic wiring details... Answer This...
Transceivers
ft290
looking for mic wiring... Answer This...
Transceivers
find manual for yaesu ft2700rh
I have an old Yaesu FT2700Rh... Answer This...
Transceivers
ft 1500
how can i unlock ft1500 Answer This...
Repair Service
Find Transceiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
