Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch dryer model wtmc6300us/01
Where is the heating element located? Ours stopped heating and we have a new element to replace. Just can't find its location
  • 351 Answers
SOURCE: no heat in my whirlpool
there may be a loose wire somewhere are you getting an active supply to the element,or may be a break in the nuetral.its difficult to explain how to find out.from my experience it always been an element fault.hope this helps let me know,ans i will try and think of something else.
Posted on Mar 08, 2008
aborcass
  • 2651 Answers
SOURCE: maytag electric dryer model DE410
check all of those "relays", htey are thermostats, monitoring you temps, they should all have continuity through them if not its bad. (temp jump it out) just to see the element glow. TEMPORARIly.. you CANNOT leave any jumped out you will damaged something. HOUSE FIRE. just wanted to instill the importance of not leaving jumped out
Posted on Mar 23, 2008
MNTECH
  • 1543 Answers
SOURCE: maytag dryer model lde312 runs
Remove the two phillips screws in the dryer front at ankle hight. Pull front toward you and unhook from top. Leave wires connected. Heating element visible at lower right.
Posted on Dec 01, 2008
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Posted on Apr 10, 2009
Tip
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
WTMC3300US/01 need to locate the heater element
http://www.ebay.com/itm/Bosch-Nexxt-Dryer-Model-WTMC3300US-01-Fan-Blower-Housing-5070000460-/160948680806?pt=LH_DefaultDomain_0&hash=item257949f866
Jan 17, 2013 | Dryers
Stop drying
If it's still spinning, I think that you need a new heating element. Just go to the parts store with your model number (or, better yet, your old heating element) and pick up a new element, then install it. It's usually pretty easy (we did ours and neither of us are electricians). Make sure that your dryer is unplugged before you do anything.
That solution is for a situation where everything else is working: dryer is still turning around and so on. If the dryer won't turn on at all, that's a different problem. Good luck.
Feb 18, 2011 | Whirlpool Dryers
This is a Bosch electric dryer that is 10 years old. The heating element is gone. Is is worth fixing? Or should I buy a new one.
are you sure it is the element, and yes repairing it is a whole lot cheaper:
http://shop.ebay.com/i.html?_nkw=heating+element+dryer+bosch&_sacat=0&_odkw=heating+element+dryer&_osacat=0&_trksid=p3286.c0.m270.l1313
this should assist you:
http://www.espares.co.uk/advice/tumble-dryers/a/9/1344/how-to-replace-the-heating-element-assembly-o.html
Dec 03, 2010 | Bosch Axxis WTA4400 Dryers
Doesn't get hot, runs fine no heat
It is possible that the heating element has burnt out or a high limit switch (safety device to prevent overheating) has gone out. Element is located at the bottom of the dryer on the oppisite side of the exhaust. Looks like a toaster coil. Any break in the coil and no heat. New elemenrts can be purchased at an appliance parts house with the serial and model numbers for your unit to ensure correct part.
Dave
Jan 13, 2010 | Bosch Axxis WTA4400 Dryers
My Bosch dryer spins but does not heat up. It is
Most likely it is the thermal switch that is located near the heating elements. This switch is the device that regulates the temperature. When it goes bad, it remains open usually. Short of a burned heating element wire, this is probably it. The only other thing it could be is the switch on the end of the motor. This switch turns on the heating element only if the motor runs. Check that too. Good luck.
Nov 28, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Apr 09, 2009 | Bosch Dryers
Bosch Axxis WTA 3510 Electric Dryer Logo
167 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
