Question about Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Problem: Archos 605 Recovery code 108
  • 1 more comment
  • jtabeto Dec 25, 2008
    when i connect my archos to pc thru usb it turns on but it shuts down immediately. what cud be the problem? tried couple of soft resets but it still does the same.
  • Anonymous Dec 27, 2008
    it won't let my get on it it will but then it says shutting down
  • Anonymous Mar 26, 2009
    lo formatie y me pide que istale el disco y no lo tengo
    Problem Solver:
  • 7 Answers
This is generally due to failed firmware updates, etc....here is something to try that has worked for some others:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. download firmware from archos website and put the firmware update file directly on the root of the archos drive
6. click repair again on the archos and done.
I've been told this does not always work on the first attempt, so give it a couple of tries if the first attempt fails.
Posted on Oct 19, 2008
My archos is showing "error code 108" on the
contract your manufacturer about replacement as there is no way to fix this on your own
Jun 04, 2011 | Archos 605 WiFi Digital Media Player
When i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three...
when i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three options no, repair disk, and format disk. I dont know what to do cam body help me?
Nov 04, 2010 | Archos 605 WiFi Digital Media Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Wont start recovery 102??
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
Sky DD
Jul 09, 2009 | Archos 605 Wifi Portable Multimedia Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Error 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Jun 30, 2008 | Archos 605 WiFi Digital Media Player
Feb 18, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi 30 gb
ave got same prob mate tried to download the firmware as red on the archos site in questions and answers fairly helpful but my computer does not put the archos on my desktop for me to transfer the files rang archos in holand apperently it means it is faulty and i am n the process of sending mine back advise you o rinng them on the 02 n0. that came with the item goodluck
Jan 31, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
290 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
