Question about Ricoh Aficio SP C811DN-DL Printer
Error message SC565
After replacing the fusing unit I recieved this message. When I called Ricoh they had me turn the machine off and reinstall it. That did not work they told me they would have to send a tech out. Is there something I can do?
  • Ricoh Master
  • 2,794 Answers
Check the connections on the contacts where the fuser unit plugs in for any possible broken pieces or connectors.
Posted on Oct 19, 2008
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
May 19, 2014 | Ricoh SP C430DN Laser Printer
Fusing unit is not set properly
turn the printer off and reinstall the unit after it has cooled off (30 minutes). Then open cover B and D. Remove the fuser unit, then reinstall it properly. Close covers D and B. The error clears automatically if the fuser unit is properly installed.
If the error is not cleared, the fuser unit is out of order. Replace it with a new fuser unit.
Nov 19, 2007 | Ricoh Aficio AP3800C Laser Printer
Error code SC 565 Ricoh MP 2550
*Heat lamp consecutive on error - Broken main fuser connection
*Heat lamp consecutive on error - Check HR thermistors with SP1-106 001 (ctr) and 002 (ends)
*Heat lamp consecutive on error - Heat roller lamp defective
*Heat lamp consecutive on error - Power Supply defective
Mar 11, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh c2500 sc565 error
could be a number of issues - i would 1st of all clean the thermistors and rest. after this check the belt for any blistering. after this see if the plastic bushings on the heat roller on the belt are clean and functioning. if none of this works id replace the thermistors then the bushings and belt
Oct 15, 2013 | Office Equipment & Supplies
I have a Functional Problem. The little wrench shows on the User Tools / Counter button location and on the screen. The Functional Problem code looks like SC542-00. It tells me to shut off copier and turn...
SC542: Fusing temperature warming-up error The fusing temperature does not reach the fusing standby temperature within 135 sec (35CPM machines) or 145 seconds (45CPM machines) after the main power switch is turned on. - Possible causes - • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermofuse open • BICU defective • Power supply board defective • Poor fusing unit connection
Sometimes by going into service mode and then turn off copier and back on will clear this message or while in service mode do an error clear. But most of the time it is the thermistors in the fixing unit needs to be cleaned or replaced. I would probably call in the techs.
Mar 21, 2010 | Ricoh Aficio 450 Copier
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Nov 17, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Nov 27, 2007 | Ricoh FAX5000L Plain Paper Laser
Ricoh Aficio SP C811DN-DL Printer Logo
2,301 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
