Question about Xerox WorkCentre M20i All-In-One Laser Printer
Xerox workcentre m20i power off
Our office Xerox workcentre m20i just went totally off. We have checked to plug both to the wall and to the machine. Turned the machine off and on several times. Unplugged it from the wall into a different wall jack. And nothing helps. Any suggenstions? It was running fine all morning.
    President:
  • 2,072 Answers
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
Posted on Oct 16, 2008
  • 3 Answers
CHANGE 3 1000MIC CAP
Posted on May 13, 2010
  • 3 Answers
Find a low voltage power supply, its gone.
Posted on Mar 09, 2009
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
-Xerox workcentre m20i. -Yesterday turned machine
hi enviro,
so its the supply inside the Xerox is the next to be checked or fuse too..a technician nearest you can help open it.
mastergani
Jan 21, 2011 | Xerox WorkCentre M20 Black and White...
Xerox worcentre 3319 vista drivers
humm.. I do not recognize this model. But I guess this could be usefull
Mar 26, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Where do you plug in the telephone jack
To connect the machine for use as a fax machine, plug the cord into the left side of your machine, lower phone jack labeled LINE and the other end into the wall phone jack. To connect a telephone to your machine, plug into top jack on the left side of machine labeled EXT. Reference page 2-12 of this link to your Xerox WorkCentre M20i User Guide.
http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
Nov 18, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Electrical storm last night. Now no power on
you need a power supply. That is where the fuses are and you should not replace them.
The Power Supply should be replaced.
Jun 12, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Changing print properties shuts down all open programs instantly!
I would first of all Go to the Xerox.com site and go to Drivers and downloads for the M20i and install the newest firmware. I believe the current version is 3.4.
I believe your problem would be resolved in loading the newest machine firmware.
May 05, 2009 | Xerox M20I Printer
Xerox workcentre m20i turns off
Sounds like the machine software is corrupted.
Try this first. Turn the machine off, then on back, there is a panel on the back cover with to plastic tabs that will release it. Pop that off and remove both memory sticks.
With the sticks removed, turn the machine on and let it come to ready. Shut the machine off , replace the memories and turn the machine back on, That reloads the machine software cleanly.
If that does not work. Go to Xerox.com, click on support and drivers, enter M10 into the search box, then click on Drivers and Downloads. Once there go to the firmware and download in with the instructions . I think the level is at 3.04 now. follow the instructions to install the firmware.
One of those 2 should resolve your problem.
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox M20I SCANNER
You can only do scanning on an M20i with a USB or parallel cable. That machine does not support scanning via an ethernet cable.
Oct 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
1,056 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
