Question about HP PL4260N 42 in. Plasma HDTV
After replacing y-sustain board have nothing but vertical lines on screen
After I repalced the Y-SUS board, turned the TV on and now the screen comes to life as it didnt before, but all i have are vertical multicolered lines running across half the tv on the right side. Any idea what this might be and how to fix it?
  • 1 more comment
  • natiyati Oct 16, 2008
    hmmm, so if i buy one from shopjimmy, anything else i can expect?
    not sure what you mean about rating. I was just asking another question and only way i could see to do that was repost. Site is not most intuitive in the world
    and how do i do that
    Scholar:
  • 191 Answers
This might be problem with fluctuations in voltage. So make sure your voltage stabilizer is working properly. If yes it is better to contact the service person to fix it.
Thanks & regards
Posted on Oct 16, 2008
    Master:
  • 538 Answers
Well..sounds like the main control board to me..these things tend to fail as a group, by the way...
  • 2 more comments
  • A Womans Computer Man
    A Womans Computer Man Oct 16, 2008
    well..sure not much help when you rate a short answer too quickly..
    of course, that may have been a mistake, right?
    that part is clear..just change the rating from thanks for trying to helpful or fixya, if you want to continue this
    log into your account, and look at your solutions.then pick this one, and then revert the rating..unless it is locked in..
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
Nov 28, 2015 | Hitachi P50H401 50 in. Plasma HDTV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Color lines on 42inch vizio
Hello
The y SUSTAIN board to your tV is faulty. It should be repalced.
Feb 29, 2012 | Vizio P42HD Television
My 50 inch vizio plasma tv has a 7 inch blue line down the center of the screen and there are a couple white half iunch lines in the center of that. if i hit the input button it will disappear and then...
Since the lines are vertical, the image is lost sideways and the corruption changes with the image then clearly this is a sign of Y-Sus failure, not the Z-Sus or the buffer boards.
An logic or input board failure would affect the entire screen, not just a part of it and a failure in one of the buffer boards would affect strictly defined lines of pixels and the defect would be constantly there all the time.
Since you haven't told us the exact model i can't point you to a replacement board.
Aug 06, 2011 | Televison & Video
Started out as no pic but still had sound - expert told me to replace z sus board which i purchased and did! now there is no pic and it makes a popping sound when turning it on to test it! Took tv to...
the y and z sustainer are always suggested to be replaced at the sametime as they work together to power the frontlight to the screen. sounds like the z board you got my be faulty with the popping noises, try to distriguish where the popping is coming from, also your issue does sound related to the y board and z board.
Apr 16, 2011 | Televison & Video
I have a Toshiba 42HP66 Plasma and I have no picture or sound. It worked great and than the next time I turned it on there was nothing. It would turn on and turn off right away. I had pulled the wires to...
I have another model Toshiba LCD tv and have had the immediate turn off problem a few times before. What has worked every time for me so far is to repeatedly press the power button (on, off, on, off) about ten times or so. Then turn it on and see if it stays on this time.
Mar 05, 2011 | Toshiba 42HP66 42 in. LCD Television
Hi. I have a Philips Plasma TV model no. 50pf7320, and I have not been able to track down the problem which goes as this: after replacing four 58" z. diodes on the Y "Sose" board, together with 2 fuses,...
You have a bad lower Y-DRV (or buffer, which ever you like to call it). If you want, you can change the IC itself... but they are usually smothered in hot glue. This board attaches to the Y-SUS that you were working on. It is common for the Buffers to knock out the Sustain board. I hope this was helpful, best wishes.
Oct 06, 2010 | Televison & Video
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
I have a Hitachi tv and tonight the screen went blank but the voice remained on. does anyone know how I can fix it????
Usually it is the Y-sus that has the problem. This is one of the boards that sustain the picture on the screen.
For this particular issue, there could also be issues with the y-drives and Z-sus. The way to find out for sure is to take the voltages (Va, Vs, Vcc, etc) on the boards and matching them up with the specified values on the panel.
Oct 13, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helsp anyone with similar issues.
Mar 02, 2008 | Dell W4201C 42 in. Plasma HDTV
HP PL4260N 42 in. Plasma HDTV Logo
229 people viewed this question
Top HP Televison & Video Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
