Question about Amprobe Digital Megohmmeter, Model# AMB-45
Refrigerator my refrigerator defrosts and leaves a mess on the ref. bottem.
    Problem Solver:
  • 6 Answers
There should be a drain hose that takes the melted ice (water) out the back and down into a pan under the refrigerator where it evaporates. Check inside the lower part of the freezer for a small hole-it needs to be clear to let the water run through the tube and down into the pan. The tube can usually be disconnected behind the unit to clear it out with a wire or hanger. Good luck
Posted on Feb 03, 2009
Water leaka from bottem in mornining
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 07, 2011 | Kenmore Top Freezer Refrigerator
I have a water leak in my Maytag MSD2454GRQ. It run down the back wall of the freezer and pools at the bottem where it freezes. It just keeps builds up on the floor. I clean the ice out and it just begins...
Leo Ponder
imufo2
Aug 22, 2011 | Maytag MSD2454G Side by Side Refrigerator
Water leak in front bottem side under freezer side
The drain for the defrost water is frozen shut or plugged...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Maytag MSD2756G Side by Side Refrigerator
Freezer section is cold but refrigerator section will not cool because of ice build up on evaporator coils in freezer and air can not flow to refrigerator side. I manually defrosted it two weeks ago but...
Find defrost timer normally located behind the cover plate for the fresh food temperature thermostat. It will have a one way adjustable screw head on it. Turn the screw slowly until you hear a click (this would normally be where the defrost would begin) leave in this position for an hour or until you hear compressor kick back on. If you have water in catch pan of refrigerator you have bad timer. Otherwise you have bad heater or defrost thermostat. To check heater and thermostat I would go to parts site on Internet and type in model no. And see if they have diagnosis videos on this or similar ref. Otherwise buy the heaters and thermostat remove shelves, ice maker etc. To get to the liner of ref. Remove it and you can then remove and replace the heater and thermo. Be very careful as the cooling fins are sharp as razors.
Aug 04, 2017 | Amana ARS8265B Side by Side Refrigerator
I HAVE A MODEL MT21LMXKQO4,WATER IS DRIPPING FROM THE IASIDE BOTTEM INTO THE REFRIG. COULD THIS BE THE DEF--TIMER????
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
cc
Sep 26, 2010 | Refrigerators
Ice build up in freezer...Auto Defrost not working Model unknown...smaller model...about 5 feet tall...2 feet wide...freezer on top..no ice maker. Bought in 2002....noise during defrost quit about 2 months...
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from repairclinic.com
Jan 31, 2010 | Roper Refrigerators
FREEZER WORKING BUT FRIDGE NOT
Remove the rear panel in the freezer and see if the evaporator coils are frozen over.
If so dethaw coils with a hair dryer.
Reassemble freezer and set controls to the normal position.
Although you replaced the defrost timer if the coils were frozen over in the freezer no air can transfer to the ref. section from the freezer.
If you do not want to dethaw the coils unplug the ref. for 1-2 days and leave the doors open .The coils will dethaw by then.
Jan 17, 2010 | Kenmore Refrigerators
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Door open all day Amana SXD22S2w
the evaporator is clogged with frost, just as if the defrost heater went out. Two options, remove all food and leave ref unplugged and doors open for half a day, or remove the back wall(evaporator cover) and defrost it with a hair dryer.
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE GSH25KGMBWW REFRIGERATOR WON'T GET COLD AFTER REPLACING SOLENOID
The ref is iced up because of the ice door being left open, you will have to manually defrost the ref by leaving it open for 7-8 hours,put you food somewhere else.
38 years exp burke
Sep 22, 2008 | GE GSS25JEM Side by Side Refrigerator
Amprobe Digital Megohmmeter, Model# AMB-45 Logo
Top Amprobe Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Amprobe Hardware and Accessory Expert? Answer questions, earn points and help others
