Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Ice/water build up bottom of freezer
Layer of ice on bottom of frezer only
  • Anonymous Oct 18, 2008
    A layer of ice forms in the bottom of the freezer and the icemaker is not hooked up.
  • Seasider1942 Oct 23, 2008
    Frigidaire Model FRS26ZGHW3....same problem,about to take the back panel off.................thanks for your advise..
    Scholar:
  • 112 Answers
There is a drain located behind the back panel of the freezer. If you pull the back panel off, it will be underneath a unit that looks like the radiator of a car. This pan has a hole on the bottom that will occasionally freeze up. Pour some warm water in the pan and see if the water drains to the pan under the unit. If it doesn't, use hot water or a hair dryer to thaw it out.
Posted on Oct 18, 2008
Freezer is not defrosting. it's a RF265ABPN model
Your defrost termination sensor has failed & needs to be replaced.(very very common problem with todays fridge's specially samsung)
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
Ice forms in bottom frezer of lg unit
THE BOTTOM DRAIN MAY BE CLOGGED CLEAN THE DRAIN AND CHECK THE DEFROST TIMER
Oct 24, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Side by side refrigerator leaks water from left front
your defrost drain is clogged,
on the freezer, side take off the back wall
look at the bottom under the coil
you should see hole,,,, defrsot drain
whats happening with that clogged all the water from defrost runs right out the door
Oct 04, 2009 | Refrigerators
Ice in bottom of frezer
make sure your doorgasket is sealing correctly. if the water runs out it shows that the defrost heater is working.
Aug 07, 2009 | Frigidaire FRU17G4JW Refrigerator
Tow dooe refrigerator and frezer, ice in the
likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Jun 29, 2009 | Refrigerators
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Side by side freezer
check the fan in the frezer is it running and is there any frost on the back panel of the frezer
Nov 29, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost in Freeze
Hi Frezer Frost.
It sounds like your defrost circuit in the refrigerator has gone south. This melts the ice off of the cooling coil in the freezer section every 8 - 10 hours of run time.
If you are old enough to remember the manual defrost refrigerators, that is why you had to defrost them occasionally. The ice layer on the coil acts as an insulator, preventing the coil from working properly.
Greg.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
