Ergo Baby Carrier Logo
Posted on Oct 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vaxhall corsa got a cdti corsa and the engine is turning however not starting,,, can you help me
Anonymous
Level 2:
New Friend:
  • Expert 166 Answers
  • Posted on Aug 21, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
166
Questions
0
Helped
85186
Points
505
That sounds like a inyection problem, have it checked
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Aug 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
13528
Points
26
Usually faulty crankshaft sensor can cause this.
Hi I have an opel corsa van 1.7 cdti and is failing to start on my diagnostic have a fault u2105
U2105 = Lost Comm with Engine Control System.
The ECU, (The Brain), isn't communicating with other control units within the vehicle. This could be anything from a loose wire to a failing ECU system. Get a Good Auto-Electrician to look at it as they will have a more accurate Diagnostic system to find the problem.
Corsa 1.3 cdti engine have refs but no pull
check the spark plugs or the plugs cables
Hi my vaxhall insignia battery ran down i started it with jump leads but the odometer went back to zero wanting to sell the car can you please help thanks
Check all your fuses first of all if they are all okay, then you need the computer to be reset when you battery went flat & you jump started the vehicle it would to the vehicle think you had changed the battery just needs to go to Vauxhall garage they should be able to reset then all should be working not a long or expensive job. Hope this helps Best wishes, Malcolm Campbell.
2answers
Wot is a control module on a vaxhall corsa 2004 plate
body control module it controls electric windows some models works as a an auto shut ie press remote and it will close all windows and sun roof.
2005 opel corsa 1.7 cdti cuts out while driving but restarts when turning the key.
cam sensor fault. it is the most common thing to do this. some times dont leave a code on ecu.
Car wont start
I would check ignition/ fuel delivery/ and fouled out spark plugs. Hope this helps. Also check you have a good battery in it.
Top Ergo Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you an Ergo Baby Gear Expert? Answer questions, earn points and help others
