Question about Desa International 100089 06 Electric Chain Saw
Worn plastic drive gear
The plastic drive gear teeth are worn beyond functional use.
We live in Baja California Sur, Mexico, some 800 miles south of San Diego, California.
I would rather install the gear mechanism myself than pay some 'shop technician' to do the same thing.
What would be the cost of this component, plus shipping to an Arizona
address.
Additional label data: Type EL-6 Model 107624-01
16" Bar 107704-02/Chain - 091375-02S
(There is no actual trade name on this device)
Patrick Malone
Puerto Adolfo Lopez Mateos
B.C.S. Mexico
(011-52) 613-131-5078
  • 188 Answers
Here is a link to the owner's manual... http://12.153.20.74/manuals/107705-01V.PDF. The part you need is 107713-01. You can order it online at www.masterparts.net or by calling 800-446-1446. They should have it in stock. I hope this helps.
Posted on May 21, 2009
Teeth on plastic gears for mixer are worn down
Even if you could obtain the parts, a 10 year old mixer is well past its prime.
Jan 17, 2018 | GE 106772 HandStand Mixer
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
1995 yukon grinding noise when i accelerate in 2wheel drive if its in 4 wd no noise, seems to be coming from transfer case 120000 miles when i let up on accel. its ok idrive for awhile and its fine please...
whats happening is the side gears in your transfer case are worn possible even broken ...whinieing gears are worn grinding gears are when some of the teeth are broken
May 18, 2011 | Chevrolet 1500 Cars & Trucks
Cutter roller moves up & down with a 'popping' sound. It seems as if a shaft bearing has worn out
You will have to open it up to have a look inside...favorite is that teeth go out of the plastic drive gears or a gear cracks completely...once you can see problem contact Royal at 1-800-524-0799 for parts assistance.
Nov 05, 2010 | Royal VF1700MX Shredder
I swith the tire size of my rodeo and now its no the same on the 4x4 now it sucks it looks cool but now dont feel good thanks im from La Paz Baja California Sur , Mexico
Whn you change the tire size - you change the ratio of the drive train..
Also when you go with bigger tires - the ride will not feel as good because it will be a rougher ride and you will feel the road more..
And the vehickle will handle diferently..
You can allways change e'm back..
Hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | 1999 Isuzu Rodeo
How to fix my odometer in 1991 plymouth acclaim
If the speedometer is working but not the odometer it's in the speedometer it's self. replacing the speedometer cluster is the easiest their available on ebay or your local salvage yard.
what happens is the trip odometer wears and sticks, theres a small motor on a circuit board with a plastic sun gear, inside the speedometer housing. it drives both the odometer and the trip odo
the teeth strip off the sun gear and odometer stops.
Jun 06, 2009 | 1991 Plymouth Acclaim
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
1997 yamaha timberwolf 4 wheel drive only front wheel drive work
check to see if driveshaft to rear is turning.if it is, either the ring gear & pinion gear in the differential are not making good contact either from being worn, or out of alignment due to worn bearings in differential case,or both.check if axle has back & forth play in differential,indicating worn beaings. also could be worn ring gear to axle contact in differential.check for vibration in axle while in gear increasing as you give it more gas, caused from ring gear teeth slipping past teeth on axle.they would have to be replaced together. oversize wheels & tires tend to accelerate axle/ring gear contact teeth.
Feb 16, 2009 | 2003 Yamaha YZ 250
Desa International 100089 06 Electric Chain Saw Logo
460 people viewed this question
Top Desa International Garden Experts
Roland W VanLue
Roland W VanLue
ray gallant
Tim Whalen
Are you a Desa International Garden Expert? Answer questions, earn points and help others
