Question about Toshiba Satellite 1805-S204 Notebook
Cd for Toshiba Satellite 1805
I changed the CD-Rom unit because the orginal it's bad (IDE error), but with the new CDRW/DVD Rom the notebook don't boot, appears the logo srcreen.
  • lhcarr Oct 20, 2008
    Thanks but don't work... do you have any solution?
    Master:
  • 538 Answers
Ok..when turning it on..hold down F2. to go to set up..and see if that new drive is activated..be careful in there..there are loads of things that can go haywire.
Posted on Oct 16, 2008
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
Ide error #1 a45-s150 at start up my toshiba cause I replace the orginal cd for a diferent brand and gives me problem slave master....etc.. so after thinking in everything updating bios etc... I gUESS THE...
Go to the BIOS screen....F2 at the splash screen. See if the new dvd drive is showing up in the BIOS and what interface is it listed under. It may be listed under an interface that has not been anable in the BIOS, highlight the device or interface, hit enable and then hit F10 to save and reboot.
Oct 06, 2009 | Toshiba Satellite A45-S150 Notebook
Toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Jul 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105 PC Notebook, DVD/CD Drive. The Drive is reading the DVD but not the CD. How do I change the settings for the drive to read both
You can't just change it from pio to udma. Go to Control Panel, System,Hardware,Device Manager, then expand IDE ATA/ATAPI, then right click on Primary IDE and select uninstall. Do the same for secondary IDE. Then just reboot your system, and it will autodetect all IDE devices. After that when you check, you should not have any devices in PIO, and your burner should work correctly. If not, stick it in a hyperbaric chamber for 2 days and see if that helps. smile.gif __________________
Jul 12, 2009 | Toshiba Satellite A105 Notebook
Toshiba dvd rom
Toshiba Satellite 1400 Series DVD/CDRW Combo Drive (P000347430)
hope that helps
Jun 11, 2009 | Toshiba Satellite A105 Notebook
DVD/CD -ROM DRIVER
the same problem of mine is my drive cannot able to read DVD then i make the solution
if you have CD RAM/ROM + DVD ROM then change it to CD/DVD RAM because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 09, 2009 | Toshiba Satellite A205-S5804 Notebook
Toshiba 1805 new optiarc ad7560a dvd drive change to slave
at the back of the drive there should be some pins with platic removeable pieces,most times it will tell you which pins are slave or master and have a diagram on the case of the drive etc,make sure they are set to slave.
Mar 12, 2009 | Toshiba Satellite 1805-S204 Notebook
HL-DT-ST DVDRAM GMA-4082N. Can not write to DVD
The DVD -R +R means that you can read these types of DVDs that have been created elsewhere, it doesn't mean you can write to your DVD under the format of -R or +R. The CD is a CDRW which means you can read and write to CDs.
I don't think that a factory Satellite P100 has the ability to write to either DVD -R or +R, but to only CDs. I have a P200 that has a DVD -R +R/CDRW and it can't write DVDs. These DVDs you put in are for read only. My Toshiba A215 can but it's a DVDRW/CDRW.
Feb 15, 2009 | Toshiba Satellite A135 Notebook
CD ROM PROBLEMS?
the 1800 series probly doesn't recognize cd-r discs. The composite out requires a driver which may not be loaded.
Good luck
Nov 22, 2007 | Toshiba Satellite 1805-S204 Notebook
Toshiba Satellite 1805-S204 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
