Question about Lexmark Office Equipment & Supplies
My printer doesn't have the usb to connect it to the computer - what do i need to do?
    Scholar:
  • 32 Answers
If the printer does not have the square USB connector (USB B end), then it will have parallel. Parallel is a wide connector that plugs in to a DB25 connector on the back of your computer. These parallel port printer cables can still be picked up at just about any office supply or computer store.
What if your computer does not have the DB25 parallel port but the printer does? Well there are USB to Parallel Port adapters made specifically for this scenario. They can run $10 to $30 depending on where you go. I recomend www.Geeks.com for those. That will allow you to plug an older printer in to a newer machine.
If it's made for a mac only, there should be a small circular port about the same size as a PS/2 keyboard or mouse. That is to connect to the Mac serial bus. This is differant than the barrel connector or brick used to supply power to the printer.
Hope this helps.
Posted on Oct 16, 2008
Doesn t recognize usb connection.
check follows :- Computer's USB Ports are Working or not ?
Printer's USB cable is ok or not ?
Printer's USB Port is ok or Not ?
Change Printer's (Logic Card )Formatter Card.
Nov 24, 2013 | HP LaserJet Office Equipment & Supplies
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Printing
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 11, 2012 | Lexmark X Office Equipment & Supplies
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
  4. Reboot computer.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
Not able to print
  4. Reboot computer.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
My prnter wont install
What kind of printer? USB printer? Disconnect the usb cable to your printer If it is a USB connected printer. Uninstall all printers. Shut off computer, connect usb cable to printer. Restart computer, it should prompt you that it found a new device and wants to install drivers for it. If that doesn't work you could go into printers under control panel and add a printer. If have had more luck with the restart and finding it on its own. I hope this may help you.
Dec 31, 2011 | Lexmark X Office Equipment & Supplies
Wi-fi connection has stopped working. Green light is steady but will not print. Get message saying the computer and printer can not connect.
You need to plug in the original USB cord that came with the printer. Once that is done, try again, the computer should re-dectect the printer. If it doesn't, then a security setting on your wireless has recently changed. If so, then you need to re-run the setup that came with your printer.
Aug 30, 2011 | Dell V313w AllInOne InkJet Printer
DETAILS DONT SPECIFY WHERE TO CONNECT PRINTER- APEX AX3400G-U4802 computer
As this doesn't machine doesn't have a Parallel Port the only way to connect a Printer is via the USB.
If you've only got a printer with Parallel connection you need to get a Parallel to USB Adapter.
There are 2 types of Adapter depending on what type of connection your Printer has (examples at links below).
http://www.amazon.com/Sabrent-SBT-UPPC-Parallel-6-Foot-Printer/dp/B0007UVRVO/ref=sr_1_1?ie=UTF8&qid=1310762929&sr=8-1
http://www.amazon.com/Cables-Go-16899-IEEE-1284-Parallel/dp/B000UX21PY/ref=sr_1_2?ie=UTF8&qid=1310762929&sr=8-2
These are just examples to show you the 2 types and cheaper options are available.
Jul 15, 2011 | Computers & Internet
Computer can't communicate with printer
whatever be the OS, get into control panel, go to printers and see the printer that you are using is set as default,,, there would be a check mark on that printer icon,, if not make it default,, and try again, If you are using a usb cable connect the usb cable of the printer to the back usb ports and try,, use the printer driver disk that came with your computer, perform a reinstallation of the driver
Feb 05, 2009 | Lexmark X2470 All-In-One InkJet Printer
Hp photosmart 7850 doesn t make conection whit my hp pc
Do you have windows xp for os ???? If so deinstall your printer on your computer and disconnect your usb connection.
First install the driver by putting your cd in your computer...Some product will tell you when to connect your usb cable to your computer...if not, make sure your driver is correctly install. After, reboot your PC and plug-in your usb cable and power up your printer....
Mar 26, 2008 | Office Equipment & Supplies
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
