Question about Pentax ZX-5 35mm SLR Camera
Film advance about half the exposures show overlap - is there an easy solution?
    Scholar:
  • 185 Answers
Halbert28,
a slipping take-up spool is not an easy solution to fix, there is a couple things that you can do that might help.
1- after the film is loaded and # 1 on the counter rotate the re-wind knob to make the film tight.
2- gently pull up on the pressure plate inside film door to increase pressure on the film. other than that,the film take up mech. must be repaired.
Posted on Dec 14, 2008
When you put the film in the meter thats shows you how many exposures you have left stays on the s instead of going to one. The film is being pulled properly and is acting normal but even the sound doesnt...
I would definitely be concerned that the film is not advancing. I have a Minolta that has the same problem. I missed many a picture because I didn't pay attention to the meter showing the film advancing. I would just make sure the film is advancing by taking a couple shots with the back open before closing it.
If you are positive the film is advancing, it really doesn't matter what the meter says as long as the film is stopping after each exposure.
Finally, if the film is advancing , but the meter is not, and you want it to, you will need to see an experienced repairman to correct it.
Good luck.
Thanks for using Fixya.
Apr 27, 2011 | Minolta Maxxum 7000 35mm SLR Camera
I took 4 rolls of film in for development but when I got them back all of them were either very under or overexposed despite taking all the pictures according to the light meter in the viewfinder of my...
Are you looking at the picture as in a print OR are you holding the negative up to the light and looking at it that way. Don't touch the negatives, they should be in a protective sleeve but you can see through it. You should be able to see if the spacing between the frames is messed up and if you have lighter and darker negatives. Looking at a print from an automated one hour service isn't worth the time of day to determine a problem. The Pentax K1000 is the work horse of the century for students learning photography and a lot of them have seen extensive use, also the camera is quite old. What I expect is if the negatives are showing overlapping frames AND the exposure is off sometimes over and other times underexposed then the camera needs service lubrication and adjustment. It's great that the light meter is working but the shutter speed could be off and the advance is skipping giving the overlap. I don't know where you are in this world but in Canada that's a $80.00 to $120.00 fix and have the repair person change the light seals while he/she has it apart.
The Pentax K1000 is still a great camera it's up to you whether or not to spend the money. I can't tell you what to do but I can suggest that if you are going to shoot film you find some place that does it with a little more human touch. Hope this was a help
Jan 24, 2011 | Pentax K1000 35mm SLR Camera
I have a half way through film in my Nikon F80 and I have changed the batteries. At first it wouldn't go on, there would be the error sign blinking after turning it on. I turned it on and off several times...
You can force your camera to rewind, but you will have a partially shot roll of film. If you continue to shoot your counter will be off but when the film cannot advance any more the camera will rewind.
Jul 27, 2010 | Nikon F80 35mm Film Camera
OVerlapping frames
This is due to a poorly manufactured and designed camera: it IS a Holga, after all...
What's happening is that the film advance is allowing the film backing paper (which has the numbers printed on) to slip relative to the film. All you can do is to learn when to compensate by advancing the film a little more than the numbers indicate.
Given that most Holgas are only designed to last for around ten to twelve rolls of film (they can last far longer though), you might not have to put up with the fault for much longer.
May 14, 2010 | Holga 120SF Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My meter won't work even with new batteries?
I have Nikon EM myself and I have an issue with meter myself. First, the camera won't start metering unless your film counter is at 1 position. So, you have to advance couple of frames in order to have the camera start metering. Second, my unit will show metering information when I press the shutter half way IF I have not advanced the film to the next frame. As soon as I advance the film and ready to take the pic, the meter needle drops and won't show any information. This is caused by the aperture arm of the camera dropping a little bit from it's initial position as soon as you advance the frame. Funny thing is that the camera will continue to meter and make correct exposure, just without the information displayed.
Aug 06, 2009 | Nikon EM 35mm SLR Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Noblex Pro 60/150 film overlapping
Just got mine as well! Awesome! mine also overlapped but it is simply a film loading issue. Make certain the film is loaded with the winding nob in the "S" position when the arrow on the film aligns with the red dot. Wind on to shot 1 and it will click and stop. All shots should then line up.
Another tip - take images 1 and 2 of the same pic at the same exposure of the exact same scene. Assuming the rest of the images are taken with the same lighting situation over the next hour or so your local lab should be able to clip test image 1, then process the remainder of the film ("push" or "pull") to give 5 remaining images exposed spot on!!
Cheers from Ralph!
Aug 06, 2008 | Noblex PRO 150 EII Medium Format Camera
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
Oct 10, 2007 | Bronica ETR-Si Medium Format Camera
Pentax ZX-5 35mm SLR Camera Logo
73 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
