Question about Microwave Ovens
Emerson MW8992RD Microwave Oven 2005
All the settings work, except Power Level 10. Thanks for your site, and kindness in helping others.
  • 1 more comment
  • dianna_leigh Oct 20, 2008
    It doesn't matter that it is the default, it matters that it does not work. The manual only tells me how to operate not to troubleshoot this problem. Please be more specific. And thanks for trying.
    Are you saying it won't cook on power level 10 (or the default power setting) and that it cooks on lower power settings? YES
    Or is it running without heating? ON LEVEL 10 ONLY
    Is it doing this on all power level settings except 10 / default? YES
    Thank you.
  • Microwave Ovens Master
  • 9,098 Answers
Power level 10 would be the default - what it is set to unless you manually set it lower.
Power level 0 (zero) is often the setting to use if you just want to use the oven as a timer.
Many Emerson microwave owner's manuals are available for free download here.
Would that answer your inquiry?
If not, please write back with more details.
Posted on Oct 20, 2008
  • William Miller
    William Miller Oct 20, 2008
  • William Miller
    That's really really odd... some odd problems are a result of glitches in the controller.
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    If you still have trouble, I would suggest contacting Emerson. If it's still under warranty, they'll fix it free.
    For more help from Emerson visit here or get help using your appliance at 1-800-898-9020.
    Get help locating a servicer or parts at 1-800-695-0098.
    We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer now that we have offered a solution.
Temperature at 10 power level
It does not work that way. The microwave OVEN generates (electromagnetic) microwaves that are absorbed by the molecules of the food in the oven, the container and the air.
The absorption rate depends on the molecular composition. After enough microwave energy is absorbed the overall temperature increases and the food is warmed, heated or cooked. If your mixture is inhomogeneous some parts absorb more energy while other absorb less and you can have hot spots.
The power level by itself won't give you an indication of the temperature because you need to know the time that the power has been applied. In simple terms Energy =time*power. The temperature reached is somewhat proportional to the energy, that makes it dependent on the time and the power.
Dec 22, 2013 | Haier MWM0925T 0.9 cu. ft. Microwave With...
Where is the light bulb in a emerson mw8115
It is inside the outer shell of the microwave, remove the outer shell to access the bulb, the srews that hold it on are on the back of the oven. You will need to disconnect power of course and do the work in an area that alloes you access to rear of the oven.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 18, 2012 | Emerson Black Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
I have an Emerson MW8992RD model and just opening the door blows the fuse! any idea ,could it be a bad door switch? if so where can i purchase a new 1?
Definitely sounds like a defect or misadjusted door switch. This site has venders of M/W parts. FYI,Federal law requires a leakage test after door repair, magnetron replacement or interlock repair.
Jun 20, 2010 | Emerson MW8987B/W Microwave Oven
Need to replace the glass tray for Emerson Microwave Oven model #MW8992RD
Glass tray replacement for the Emerson Microwave MW8992RD has been discontinued.
Oct 06, 2009 | Emerson Microwave Ovens
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
Help inside tray will not rotate
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Even though yours may not be there, there might be one close enough to help you .
Mar 01, 2009 | Microwave Ovens
How do I set the power level?
On our site, we have three different older Emerson microwave manuals you can download free: MW8103SS http://207.234.249.73/mwd/mw8103_om.pdf MW8104SS http://207.234.249.73/mwd/mw8104_om.pdf MW8627W http://207.234.249.73/mwd/mw8627w_om.pdf If none of these is close enough to help you, you can e-mail us a photo of your control panel and we should be able to give you some operating tips. You can e-mail us through our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 28, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
294 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
