Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE7500AYW - Won't start - Message says "A power failure..
When the start button is pressed the dryer beeps and this message comes up: "A power failure occurred during the current cycle. Press "Start/pause" to continue this cycle" When I press ok and go back to the cycle it beeps and the message continues to come up.
I had a repair service out last week and he got it started. Said the wiring was slightly loose inside. Tightened some interior wires. Dryer worked fine for several hours and started doing the same thing.
I have check the circut breakers, the plug going into the wall. Any ideas?
  • Anonymous Nov 10, 2008
    Same exact problem. Have repair coming tomorrow.
  • bdefazio12 Dec 17, 2008
    My dryer gives the same message, but if I bring up the service screen, then choose SYSTEM CHECK, and hit motor ON, the motor and heat and sensor will all go to on status without any further diagnostics. The odd thing is, sometimes I've had to do it literally 50 times to get it to start. It tries each time to turn the drum, then eventually seems to "warm up" enough to succeed. When it is running in the System check mode, the display alternates between "short circuit sensed" and "short circuit not sensed", without ever displaying an error code.
I had the same problem. It turned out a power transformer in the neighborhood had gone bad. I found it by checking power at the receptacles in the house and we weren't getting proper voltage throughout the house. We had enough power in the house to power lights, the TV, coffee maker etc. but not enough for the dryer. I called the power company and they came out to do a check. At first they said there was a wiring problem with the house until all the neighbors started coming over after seeing their vehicle and saying they were having problems. So maybe you aren't getting proper power to the unit.
Good luck. Hope this fixes your problem.
Posted on Jan 14, 2009
Maytag neptune Dryer won't start. Get an error
reset the dryer .disconnect the power cord by 30 -40seconds, and try again, if the problem persist with the error, read you owner manual in troubleshootign section. or dwonload the owner manual for identify the error problem, can be problem a temperature.
go to www.retrevo.com
God bless you
Jul 28, 2013 | Dryers
Maytag neptune error message e5
This normally indicates that the thermistor is bad. Try measuring it to prove it is OK. It should be 10K Ohms at room temperature (20C / 68F).
If necessary, replace it then clear the error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Sep 06, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Hello all, My MDE7500AYW Maytag Neptune Dryer was working today and just quit. It is plugged in and the drum light works when the door is open, close the door and nothing. No LCD display, no...
looking at schematics looks like you main control board is the faulty part. you have done a very good job of tracing the voltages from the source. been that all voltages are present and door switch is good the part left is the control board. here is the part# 33002886. you can find it at sears website or service center.
good luck to you.
Feb 15, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Error message appearing "power failure occurred
Push the Start/Stop button on the Neptune to reset the machine.
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
MDE5500AYW MAYTAG DRYER WON'T START
pf means power failure. your dryer uses an extra boost of power on start-up and your is failing to get this boost you need a repair person in your area
Feb 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MAYTAG NEPTUNE GAS DRYER
Unplug the unit and take off the cover where the cord goes in. You may have one burnt wire under that cover.
Mar 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
869 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
