Question about Nikon Coolpix L11 Digital Camera
Flash setting I downloaded and read the manual on how to set the flash setting on my Nikon Cookpix L11 and I still don't get it!  Can you help? Many thanks
  • mdmbutterfly Dec 10, 2008
    Thanks so much for your assistance!  It worked perfectly!
  • 158 Answers
You press the lightnening bolt button (flash button) on the circle and a range of options will appear on the screen in a menu. Go to the lightnening bolt option on the menu and make sure it is turned on. (The one in a circle. Make sure it isn't the one crossed through.
Hope this helps. Please rate this solution.
Posted on Nov 30, 2008
There is a red flashing light on my camera
Your camera's clock is not set. Go into the setup menu and set the date and time.
Apr 17, 2010 | Nikon Coolpix L11 Digital Camera
Internal flash not firing on nikon d40
Make sure you have read your user manual and know how to use the camera, including how to use the flash.
Go to the menus set all settings to factory settings. Later you can set them the way you want. Make sure all settings are set to make the flash work when you want to use it. Some settings will turn off the flash.
If you need technical support or repair consider calling Nikon. Go to and browse to the support section, find the repair and the toll free number. Call and see if you can get help on your camera.
Nikon has an up-grade or trade-in program for refurbished units if your repair is too expensive.
Oct 22, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
I want to shut off the flash.
On the back of you camera there is a sign that looks like a lightning bolt. Press the button while the camera is on. You will be able to set the flash to be forced off while taking photos.
Sep 28, 2009 | Nikon Coolpix L11 Digital Camera
Pictures are blurry - have the red hand flashing
select flash in auto... normally when you turn off the flash. the hand appear...
Aug 06, 2009 | Nikon Coolpix L11 Digital Camera
Unfocused Pics
If you use the "macro" setting (the flower symbol on the command dial), and are holding the camera steady, it should work. Try to ensure sufficient light by shooting near a window. You should also disable the flash by using the arrow on the dial to go to the "no flash" setting. The main problem is most likely that you are shooting close to the images, so the macro setting is a must. Good luck.
May 23, 2009 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11 Digital Camera-Flash does not work
make sure your'e in the right scene mode. because mine when its on the "landscape mode", the mode doesnt allow flash. try portrait, close-up mode, etc.
Nov 10, 2008 | Nikon Coolpix L11 Digital Camera
Flash & Blur Problems
if you not wish to use the flash, increase the ISO so your photo won't blur
Jul 30, 2008 | Nikon Coolpix L11 Digital Camera
Help flash Nixon coolpix L11
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11
I had the same problem with the Nikon 3200 Coolpix, the flash only worked with certain mode, as scene mode. I solved the problem doing a RESET ALL that is in SET UP menu.
Jun 12, 2008 | Nikon Coolpix 3200 Digital Camera
Flash Not firing
Hi , try to flash in dark area and set camera flash on set in all option.if does not fire the flash the flash bulb are busted either the the igniter switch inside was broken.
May 07, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
41 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
