Question about Canon NP 6050 Copier
Canon ImageRUNNER 300S - Replace Drum
I am trying to find simple, easy to follow instructions on how to replace the drum on our office copier. Installation is going to cost way too much and we feel like we can do it between the 6 of us!
Can anyone give me step-by-step instructions?
  • Bevbot Oct 20, 2008
    Thanks so much! As soon as we get the drum from our supplier, we're going to try this! I'll let you know how it goes!
  • Canon Expert
  • 270 Answers
All you have to do is have a phillips screwdriver and remove the screw that secures the drum to the copier. Before removing the screw you need to release the developer unit out of the way. Just perform the same procedure as if you were going to put new toner into the copier but you don't have to pull out the developer unit. Then just to left is the drum unit and at the top of it should be a black screw. It will be about an inch long. Then just pull out the drum and put in the new one after removing all the packing material. Be sure to not touch the round cylinder of the drum unit, that is the drum. Also, you may want to practice put in the old drum several times before putting in the new drum until you're sure you can put in the new one without damaging it. There is another thing that should be done but that is a technician thing and is probalbly beyound what you am7y want to deal with. It doesn't really ahve to be done but a tech should do if he replaces the drum for you. It most likely would not affect copy quality and will not hurt the drum if not done. Good Luck and be careful.
Posted on Oct 17, 2008
How do I replace the drum?
Nick
follow the instructions in the user manual
step 1 - purchase a replacement drum unit
step 2 if you do not have a user manual download user manual click on this link http://electronicbusinessmachines.com/wp-content/uploads/2015/04/iR-1023iF-Basic-Operation-Guide.pdf
and read page 173 to 175 replacing drum unit section 12-12 in maintance section of manual
Sep 17, 2015 | Canon imageRUNNER 1025iF
Our small office purchased a Canon Imagerunner 2000/1600 copier 4 years ago. Since our last service call, when the drum was changed and the machine was cleaned, we then ran less than 2000 copies. The...
When your drum was replaced did they put in a new drum assy or just replace the drum cylinder? I would purchase a new drum because these are one of the chepest to buy, around $ 80.00. They have a 6 month warranty and around 20,000 copies. I would replace the drum to see if that solves the problem. Before doing that, pull off the left side bypass assy. It is easily removed without tools. You should be able to see the drum and see if the drum is clean. If not, then replace the drum unit assy. Are you using only Canon toner, no other kind of brand will work. Generics should work but they are usually not as good a quality. The volume is very low and that should not be an issue. I believe its suppossed to handle 10,000 copies per month. Cleaning the glass top and below may help. The mirrors should also be cleaned as well. Good luck.
Dec 01, 2010 | Canon imageRUNNER 2000 Copier
Double images showing up on imagerunner c6800 when using color copies only
unfortunaly to tell you the only real way to have this problem fixed is to replace the drum and the drum blade.... though it might be possible to clean the drum depending on how bad the drum has gotten
Apr 20, 2010 | Canon imageRUNNER C6800 Copier
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Canon Image Runner 3300 How to Replace Dum?
the canon drum are not need to clean it coz it clean automaticaly through cleaning blade, & replacement of drum n blade is very easy its like canon np 2020 type unit
Mar 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Remove, refurbish/swap,replace drum canon 15000
That drum is $1500.00 retail price and takes 2 hours labor to replace it. There is no way out. Buy the drum and they can get it installed in 2 hours
Jan 11, 2009 | Canon imageRUNNER 5000 Copier
ERROR CODE E000020-01b0
your yellow drum unit is bad replace it if the error ship to 000020-02b0 replace all your drum unit because all the units could be bad but the machine will show one at a time as you replace the drum units
Jun 13, 2008 | Canon imageRUNNER C3220 Color Copier
Canon NP 6050 Copier Logo
263 people viewed this question
old marine
old marine
