Question about Uniden Cordless Phone
Handsets are saying searching can not use the phone
  • bthomson458 Nov 03, 2008
    the extra phone ge 26921 keeps reporting "Searching..."
  • deelight65 Nov 19, 2008
    I bought a trio of Phillips CD245 on ebay reconditioned when i got them yesterday there was no instructions, All 3 handsets have the searching on them and i dont know what to do, I have taken the batteries out and replaced them but to no avail, I cant even get a dialing tone on them. HELP !!!!!
This is a portable home telelphone. I removed the batteries, waited a few minutes, and replaced the SAME batteries. Now the phone works perfectly. Maybe it needed to be reset?
Posted on Nov 17, 2008
I suspect this is for a portable home telephone. I have three handsets that I purchased as a set, of portable telephones. When the battery goes to "Low Battery" it cuts out and the phone displays "Searching..." I got so annoyed that I went out and bought new Panasonic phones. These are not new phones, and I am just sick of the problem.
Posted on Nov 16, 2008
I had the same problem and I replaced the power supply for the base unit and that solved it.
Posted on Nov 08, 2008
    Problem Solver:
  • 12 Answers
What kind of phone are you dealing with.. i assume its a cell phone... what brand ... it sounds like the antenna is messed up or no longer connected to the motherboard in the phone ..
Posted on Oct 16, 2008
Display keeps saying 'searching'
I don't have this model but I have had two Siemens phone systems. Typically, when the handset says "Searching" it is trying to connect to the base station (the part actually connected to the phone line). This can happen if the handset is too far from the base station to connect to it wirelessly. It can also happen if the handset has become unregistered from the base station (or was never registered to begin with). If the distance issue is not the problem, look in your documentation for how to register the handset and give that a try.
Sep 07, 2014 | Siemens Gigaset 4215 Cordless Phone
Phone says "searching"
When a cordless phone comes up as searching, it's looking for the base station. If all the others work, it's probably be the handset is defective.
Nov 22, 2013 | Uniden D1384-4 DECT 4-Handset Cordless...
Handset says searching
Searching means its searching for a signal. If the phone cant contact the base it will say searching. Make sure the handset is in range of the base and the base is connected to the power.
May 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
My handset says "searching" and won't make
Make sure the home base is plugged in and functioning, and that the base for the expansion handset is also on, plugged in, and functioning.
Feb 28, 2011 | Uniden DECT 6.0 Cordless Telephone...
Handset reads "searching"
The reason the handset says "Searching" is because it can not find its Base Station. What handset works with a notebook? I had not heard of such a thing.
Sep 15, 2009 | Philips VOIP3211S/05 IP Wireless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Dec 22, 2008 | Philips DECT 2252S Cordless Phone
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Jan 28, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
143 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
