Question about Canon Office Equipment & Supplies
Rollers for paper feed
The rollers for the paper feed are too tight. The paper is being crinkled as it is beding fed.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
What do you mean too tight ?????????
check the path and make sure there is nothing catching the paper
Posted on Oct 16, 2008
Paper misfeed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Dec 19, 2011 | Copystar Office Equipment & Supplies
Paper is not feed
Nov 28, 2011 | HP Office Equipment & Supplies
I cant get the paper to feed without jaming is ther a way to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 27, 2011 | Canon Office Equipment & Supplies
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper will not go through printer and also crinkles when comes through the printer
When the paper does not feed straight, then dirty or stickyrollers can cause the paper to jamb or crinkle.
Jun 01, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Paper feed Ricoh Aficio 1015
Is the copier not feeding? There are many problems that could be causing this.
- The feed roller could be dirty or worn. The feed roller sits on the upper right side of the paper tray -- it's a thick gray roller. Clean this roller with a lint-free rag and some alcohol.
- The paper fences might not be tight. There are two paper fences (one toward you and one on the far side of the paper, away from you). Make sure these fences are tight enough so that the paper does not move around in the tray, but not too tight to keep the paper from being fed out of the tray. Also make sure the green guide on the left side of the paper is snug but not too tight.
- The paper could be damp, curly, or full of static. Damp paper is a big problem, especially in the summer. Try filling the tray with a fresh **** of paper and see if it feeds through better. Also make sure none of the pages in the tray are bent or folded under.
Did any of these suggestions help?
Aug 28, 2010 | Ricoh Aficio 1015 All-In-One Laser Printer
Dell M5200n Printer is crinkling Envelopes
If you have the option to print in Horizontal or Vertical feed, try the Horizontal option and be sure the feed guide slide is not too tight against the envelope.
Feb 24, 2009 | Dell Office Equipment & Supplies
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
52 people viewed this question
old marine
old marine
