Question about Gateway 400E (400EB) PC Notebook
Gateway M460E Wont power up
Model M 460E it wont power up,with or without the battery in place. When using the A C adapter, when you press the power on button a red light flashes on the front of the laptop.
    Scholar:
  • 32 Answers
That typically indicates a powersuplly malfunction (not providing enough power) or, more likely, a motherboard issue.
The best way to rule out the first part, which is the easiest, is take it to a local repair shop or radioshack and see if you can borrow a power supply to test. Make sure it is the same voltage and similar amperage. This information can be found on either the bottom of the power supply brick or the bottom of the laptop itself. Something like "19V 4.3Ah" which means 19 volts DC at 4.3 amp-hours, or amps. Amps are not important at this stage just for quick testing. Using a power supply with too few amps could burn out the power supply exceptionally quick.
Most of the time you can get replacement motherboards on eBay for cheap. The down side to this is that laptop motherboard replacement is far from fun. From experience, I tend to avoid repairing laptops due to that fact. You could be exceptionally lucky and have a special, seperate, power board inside the laptop. This is not common and not likely. It is most likely connected directly to the motherboard.
If it is truely the motherboard and you found a cheap replacement, the cost of professional installation could warrant the cost of a new laptop. You could always compensate for the price of a new laptop by selling your current one "as-is" on eBay.
If you do dispose of your laptop, you can always pull the data off the hard drive. Easier than it sounds unless whatever caused the motherboard to fail caused the hard drive to fail as well. A simple 2.5" laptop hard drive to USB adapter can be found for mere dollars and allow you to plug your laptop hard drive in and copy the data off it. I carry a 30gb laptop hard drive in a usb encloser with me all the time.
Hope this helps!
Posted on Oct 16, 2008
    Master:
  • 538 Answers
Not good..sounds like either the power supply has not enough juice, or the mother board is unhappy..check the power supply for proper voltage as indicated on bottom of the power supply..
My gateway m460e wont charge or turn on there are no lights the mother board is dead.what cause this?
Assuming the charger is ok and the battery is ok, you may have a main motherboard fuse which has blown (would explain the lack of power), if the fuse is not the issue, then it looks like there are other damaged components on the board
Jan 10, 2011 | Gateway M460 Notebook
Computer wont power on although both lights come on and battery is charged
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad
Sep 17, 2010 | Gateway MT3418 Notebook
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
I left my laptop turned on in my office when i came back then next morning it wont start even if I push the power button. The laptop was turned on when i left it.
Try to perform power drain. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in then plugin the power adapter then trn on the computer. You can also power on the computer without the battery. If your computer wont turn just using the power adapter then there is a possiblility that there is a problem with your power adapter.
May 19, 2010 | Computers & Internet
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
I JUST GOT A GATEWAY M465E NOTEBOOK ON 07' ,IT WONT POWER ON!!! I THOUGHT IT WAS MY CHARGER SO I BOUGHT A NEW 1 FOR MY EXACT MODEL & IT STILL WONT POWER ON! IM TRYING TO SEND IT BACK FOR REPAIR OR A...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 22, 2009 | Gateway M465-E Notebook
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Gateway ml6232 wont power on with battery or ac adapter help
remove the battery then connect the adapter and try to power on...
Jun 19, 2009 | Gateway 6510GZ Notebook
Password on boot up
This usually works with a bunch of motherboards,
1. Open the CPU.
2. Unplug it from the power.
3. Remove the BIOS Battery.
4. Press Power without pluging it in a power supply.
5. (IF you can) Try and find a pin usually 3 of them with a jumper connecting 2 of them (middle and 1side) remove it and connect the middle and the opposite side and press power on again without plugging it.
(IF you can't find it) Just push the power button for about 30 seconds without pluging it.
Vote if it helps thanks
Apr 02, 2009 | Computers & Internet
Open Questions:
See all Gateway 400E (400EB) PC Notebook Questions
Gateway 400E (400EB) PC Notebook Logo
295 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
