Look at the keyboard, in the row of Function Keys at the top are two clips, located about an inch in from each side of the keyboard, use your fingernails to pull the clips towards you and lift off the keyboard, the memory door is located under the keyboard.
The maximum is 1 GB. Standard, it comes installed with 256 MB but you upgrade with additional 256 MB or 512 MB memory modules. The modules you are looking for are:
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
I want to upgrade my powerbook G4 :
processor 400 MHz Power PC G4
Memory 256 MB SDRAM
L2 Cache (perCPU) 1MB
Bus Speed: 100 MHz
I'm looking to upgrade memory and speed !!!
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features Form Factor Mini Tower Processor Intel Pentium 4 1.6 GHz Installed Memory 256 MB (SDRAM) Operating System Microsoft Windows XP Home Edition Recommended Use Business
ur system processor and memory both will be upgrade.
Memory- RAM Technology SDRAM Installed RAM -256 MB Max Supported RAM 3 GB Installed Video Memory 32 MB
Hi, Memory Upgrade for Sony VAIO
PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM
SODIMMs Memory Type, and comes installed with 512 MB = 256 MB
(removable) + 256 MB (removable) of Memory. You can upgrade your
Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the
system has 2 sockets to install Memory, already with 512 MB = 256 MB
(removable) + 256 MB (removable) standard Memory installed. For best
for your Laptop.
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop. Standard Memory
Maximum Memory
1280 MB
Memory Expansion
1 socket
Memory Comments
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory This system will not be able to use the ram you are trying to install. For more about this system go to this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013744&lc=en&cc=us&product=95040&dlc=en
if you goto this link it will tell you what you can put into your comp you can only put in the maximum it tell you the link is http://www.crucial.com this will scan your computer and tell you everything about it and anything you can put in it.
It will also tell you everythin that is compatible hope this helps you let me know how you get on ok
