Question about Acer Aspire 5630 Notebook
Cant get to home page
Turn laptop on,reads system bios version:V3.50 system bios shadowed.mouse initialized. error. other page reads PXE-E61:media test failure,check cable. operating system not found
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sounds like the hard drive is unhappy..do you have a recovery or installation cd?
    Sergeant:
    Champion:
  • 244 Answers
Your laptop doesn't recognised hdd.
You should go to bios to see if your hdd is there.
if you don't see your hdd in the bios, most of the time is harddrive problem (dead).
In this case, you can replace your hdd.
but if you see your hdd and you get PXE-E61 error message, your OS might be corrupted.
Posted on Oct 17, 2008
PXE-E61 media failure check cable
PXE-E61 Error message showing due to Media cable failure.
You have to fix this media cable failure one must return to the BIOS screen at start up. Depending on the model of the laptop, press f1, f2, or delete to enter the BIOS screen (the computer will tell you what keys to press). At the bottom of the BIOS screen, there will be a menu. One of the options should be "setup defaults." By pressing the corresponding key, it will return all of your settings back to how they where originally.
Hopefully it will help you
Jun 26, 2013 | ASUS X401a 14.1-Inch Laptop Black Intel...
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
PXE-E61 : media test failure, check For Realtek rtl8139 (x)/8130/810x PCI fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure,check cable PXE-M0F:EXITING PXE ROM
Are you on a company network ?
As I said if you are, then booting from a network may be part of your company system.
If it is just a home computer then you have other issues which could range from something as simple as a faulty hard drive cable to a dead hard drive.
If it is a company computer on a full lan then turn boot from network back on and see if it will boot. if not then te server that has the boot source may have an error or the lan may have issues.
Nov 01, 2011 | Computers & Internet
My laptop says PXE-E61 : Media
reboot your laptop , read the screenwhen it says press ? for boot menu
press (f8) for bios
press the one that says boot menu and then when it asks you where to boot choose the one that says hard drive. when that boots up and works. you need to restart your pc and press the f8 one to go into bios, then go to the boot tab, and change it to boot 1st from your hdd. somehow it got changed and it is looking somewhere else for the boot directions and its making errors
Jul 31, 2010 | Gateway MT3705 Notebook
PXE-E61 Media test failure, check cable PXE-M0F
There are two things that could be a problem. The BIOS settings are corrupted, or the hard drive system has a problem. In order to fix the BIOS problem, at boot up you'd hit F2 (or whatever key is required to enter setup). Get some paper and pencil and go through the BIOS pages and mark down anything that is not a default setting. Find the location to reset the BIOS to default settings and perform this action. This will overwrite your BIOS settings and remove any corrupted data. Now, when you reboot, go back into the setup and set all of the settings to the choices you marked down before.
If this does not fix your problem, your hard drive control system has a problem. It could be as simple as a ribbon cable being loose or as bad as the controller section on the motherboard has gone out. Another possibility is the hard drive has given up and needs to be replaced.
Feb 09, 2010 | Microsoft Windows XP Home Edition
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Acer Aspire 5630 Notebook Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
