SOURCE: Martantz SR 3000 - Are there any remote codes
Hi, sorry it took so long for me to get back to you. The system does not give us updates on older problems.
Found the manual, and it does have 5 digit codes, Page 2 lists the codes for marantz as 0321, 0269. Hope that helps you.
regards
robotek
Click here for Comcast Remotes Five Didgit Codes hope it works for you did for me.
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
SOURCE: my marantz SR 7400 suddenly shuts down or goes
Most likely you have a speaker short, you need to check the ohms on each speaker disconnected from receiver if they are 8 ohms they should be close to that on the meter no more than a 1 and half ohm varience to what the speaker ohms says on the back. If they are ok you need to disconnect speaker wire from receiver and check for a short in the wire by connecting ohm meter leads to ends of the speaker wire you should get no reading if the wire is good. If this is all good you have a bad output transister in your receiver, but i dout this is the case because these transisters normally short to ground and blow a fuse. Hope you solve your problem good luck
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
