Question about RCA Televison & Video
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW TV. I CAN'T SEEM TO GET A SIGNAL INTO ANY CHANNEL ON THE TV.HELP!!!
    Problem Solver:
  • 12 Answers
Ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Posted on Oct 16, 2008
How do you hook up a panasonic vcr to a hitachi 1080i tv
You can use a S-Video cable if your VCR supports it, otherwise, use the plain old composite RCA cables (Those with a yellow, red and white plug).
Oct 28, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
moz-screenshot.jpgHI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Mar 07, 2009 | Samsung LN32A330 32 in. LCD TV
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
How to hook up my dvd/vhs combo to my tv with out the red,yellow and white cables
go to radio shack and get the red and white and yellow cords.
Dec 23, 2007 | Televison & Video
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Televison & Video Logo
183 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
