Need a tuner for HDTV Samsung Model #HLR4667W
Cable TV man checked out our HDTV, and said we might need a tuner for the regular channels. We are receiving the High Def. channels fine. We have no idea if we could repair this ourselves or buy the part and get a repair person. We do not know if the tuner is one system with a split for regular or High Def or if regular stands alone. Please tell us what we should do for the least expense. Our TV is only 2 years old. Thank you so much.
    Problem Solver:
  • 5 Answers
THERE IS A DIODE ON THE MAIN SIGNAL BOARD THAT HAS SHORTED OUT REPLACING THE TUNER IS NOT GOING TO HELP MATTERS
Posted on Jul 23, 2009
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ...
www.tomsguide.com/forum/53920-4-basic-channels-hdtv-cable What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
Does the RCA TV model D52W20 have a digital tuner? or will I need a cable box to watch TV? At our location they just switched the signal. we just had a tube TV with the cable line in the back and up till...
Greetings Pete - No, your display is what is called HDTV ready, meaning it needs a separate tuner AKA set top box.
You need to get the cable box, plug in the component video cables into your TV (usually provided) and plug in audio cables and you're viewing HDTV. See below:
Happy Viewing!
Regards,
Mikeywaf
May 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Samsung LN55B650, and cannot use the remote to change channels, hav eto use cable remote. I change to TV mode, and program in channels, but that option is not available once I switch to HDMI2,...
OK the cable box remote is the only one that can change channels in this case. because you are using the tuner in the cable box not the TV.
all you need the TV remote for is to turn the TV on and off and turn the sound up and down. if you used the cable input on the TV then the tv remote would be used to change the channels.
Dec 25, 2010 | Samsung LN55B650 55 in. LCD HDTV
The info states this TV has an HDTV tuner (ATSC), however I am unable to tune any digital channels which are broadcast via our cable provider (not offered on whole number channels, rather decimel points...
You need to reset you tv to factory mode, by pressing tv off---mute 182 power---go to options and look for *reset to factory* them wait until the process is done.
Dec 19, 2010 | Samsung HL-S4266W 42" HDTV
If these tv is digital why I need to use a converter box to see the channels
Because it does not have a ATSC nor a Quam tuner in it. Just a regular tuner. As it says HDTV ready. This meant back when you bought it that it will receive HD when a hd cable box is used and connected to the DVI or the Component input in the back. This was a low end set at the time. It will still receive regular cable without a box.
Nov 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
Is mhy samsung not hdtv?
You must have a digital tuner built in to the tv if you want to scan for Freeview digital channels. If you have digital cable or satellite the decoder box will unscramble the signal and send it to the tv through a scart connection or HDMI cable. Not all tv's have a digital tuner built in but if it is HDTV it can show an increased resolution image if the output from the cable box or dvd player is high definition.
Jul 18, 2009 | Samsung Televison & Video
Digital Channels??
Direct from the Hitachi website - "Integrated HDTV Tuners: Hitachi's new top-of-the-line XWX series features built-in ATSC terrestrial and cable HDTV tuners to provide integrated high resolution, high-definition signal decoding." You will need a seperate HDTV tuner if you do not have cable or satellite and want to watch off-air High Definition channels.
Apr 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Feb 09, 2009 | Westinghouse LTV-32w3 HD Television
Just got cable today, and i had to cable man attach it to the tv, and no cable. He said we have prefect reception, and the cable box is good. i get two channels fuzzy and one only a little out of the 63...
Did you check to make sure that in the options, the TV channel configuration is set to CATV or Cable mode, and not to Antenna mode?
If the above is true, the tuner module in your TV is probably defective.
You need to call in a TV service person who is familar with the type of TV you have to check the tuner.
Jerry G.
Sep 05, 2008 | Televison & Video
Tuner problem? (hope not!)
check if you put the cable in tuner A OR B CHANGE WITH REMOTE MAY BE NEED GOOD CONETION OR PUT ONE SPLIT T CABLE AND RUN ONE CABLE TO TV IN A AND OTHER B CHECK THIS NOT TRAY SPEAK SPANOL THANK YOU
Sep 27, 2007 | Philips 51PW9303 51" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
