Acer Aspire Bios Password Problem
My Acer Aspire 5570 Notebook locks up after I attempted to clear CMOS BIOS password. Need help asap.
  • Anonymous Dec 28, 2008
    exactamente el mismo
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    aohhhhhhhh..not too good..can you get back into the setup with F2 on startup`?
  • 4,338 Answers
CmosPwd is a cmos/bios password recovery application.
Follow the instruction on this site.
Copy and paste this link into your browser.
http://www.cgsecurity.org/wiki/CmosPwd
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 17, 2008
Aspire x1800
Setting up a password on the Acer Aspire prevents others from accessing the computer without permission.
If the user is unable to supply the correct password at startup, the computer will lock the hardware and fail to boot.
This security measure is a useful feature, but it can create serious problems if you forget the password.
Basics
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor.
This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output systema critical software utility that controls how the computer operates at startupaccesses when the computer boots.
If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly.
Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually.
Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty.
Desktop Models
Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS.
This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover.
Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds.
If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead.
Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot.
Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up.
Laptop Models
Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop.
Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery.
Don't take apart the notebook if you don't have experience disassembling PCs.
After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery).
All visible screws must then be removed from the bottom of the notebook.
Remove all components stored to their separate compartments on the base of the notebook.
Turn over and open the PC.
Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the keyboard.
Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover.
Remove the top cover to reveal the motherboard.
Locate and then remove the CMOS battery.
Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX."
All of these passwords are case-sensitive.
May 04, 2014 | Acer Aspire Computers & Internet
How to remove the bios password and the windows password
Step 1:
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor. This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output system - a critical software utility that controls how the computer operates at startup - accesses when the computer boots. If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly. Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually. Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty. Desktop Models Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS. This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover. Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds. If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead. Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot. Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up. Laptop Models b> Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop. Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery. Don't take apart the notebook if you don't have experience disassembling PCs. After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery). All visible screws must then be removed from the bottom of the notebook. Remove all components stored to their separate compartments on the base of the notebook. Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible. Remove the keyboard. Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover. Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire. Other Options b> If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password. These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords. Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX." All of these passwords are case-sensitive.
Mar 26, 2013 | Acer Aspire One AOD257-1497 Atom N570...
How to reset bios password acer aspire 4315 without removing d cmos battery? I ever try to use default password for bios phoenix, but useless. so please help me coz I want to reinstal windows, change it...
I fix laptops and when I get an Acer laptop locked with an unknown bios password I use www.unlockbiosrecovery.com to get the bios master password for only $20 which clears any set bios password and they guarantee it to work. I have unlocked a dozen or so Acver laptops with unlockbiosrecovery.com bios password recovery service.
Aug 28, 2011 | Acer Aspire 4315 Notebook
My Acer some how got locked up in the CMOS. Need Password.
Hi there!
AMI BIOS
A.M.I.
AMI
AMI_SW
AMI?SW
BIOS
HEWLITT RAND
LKWPETER
PASSWORD
Oder
AWARD BIOS
01322222
589589
589721
595595
598598
aLLy
aLLY
ALLY
ALFAROME
aPAf
_award
AWARD SW
AWARD PW
AWARD_SW
AWARD?SW
AWKWARD
BIOSTAR
CONCAT
Condo
d8on
djonet
HLT
J64
J256
J262
j332
j322
KDD
LKWPETER
lkwpeter
PINT
pint
SER
SKY_FOX
SYXZ
TTPTHA
ZAAADA
ZBAAACA
ZJAAADC
Russian Award Passwords:
% p%
% p%
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot
PHOENIX BIOS
phoenix
OTHER BIOS
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
SOME COMPUTERS WITH TOSHIBA BIOS
Hold down the Shift key as the computer is booting.
I hope i helped you with this list i entered as much i could research by some of my books.
Please rate my answer! =)
Sincerelly
Aleksandar Adzic
Apr 16, 2010 | Acer Aspire 7720 Notebook
Forgot the password of bios of acer aspire 5584 wxmi model: zr1
1. Go and download the bios file - ftp://ftp.work.acer-euro.com/notebook/asp.../bios/v1.06.zip
2. There should be a file call AG1A-106.EXE inside Alviso folder, just extract this file to the location you like.
3. In windows, use cmd (Command Prompt) to run this application.
4. The syntax should be ---- AG1A-106.EXE /ldcmos /reb -----
5. It may take 1 minute to load up, when it appears, just flash it.
6. Computer will restart after flashing and password should be cleared.
7. Don't forget to set back the BIOS settings if required.
Hope this helps!
Please rate my response!!
Jan 29, 2010 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire one crashed and i need help
Below are the steps for the resetting of the password. Below the steps is the link for the service manual. On page 113 is the picture of the jumper pads that need to be "shorted" to reset the cmos.
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
http://tim.id.au/laptops/acer/aspire%20one.pdf
Dec 26, 2009 | Acer Aspire One PC Notebook
Forgotten hdd/bios password
The only way to reset the BIOS password is to find the jumper pins on the motherboard and set them to the clear state and remove the CMOS battery. It resets the CMOS to the default state.
Your best bet is to contact tech support and explain the situation to them
Mar 22, 2009 | Acer Aspire 3000 Notebook
BIOS problem with Aspire 5500 laptop
hi there,
you can use this iso image booting directly from this CD-ROM and update your bois...
please download this tool using this link....
http://support.acer-euro.com/drivers/utilities.html#BIOS
Apr 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Bios Password Reset
The only idea I have is to find and disconnect the CMOS back-up battery after removing main battery and unplugging the AC adapter. That SHOULD clear the bios completely, wiping out the password, the date, and everything else.
I know this works on desktops, and most laptops, but no promises, and the cmos battery may not be easy to access.
You should probably leave the battery unhooked for at least 1-2 minutes to be sure it clears.
Hope this is some assistance!
Jan 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
