Question about Kenmore 96222 / 96224 / 96229 Electric Kitchen Range
Kenmore range 96222
Clock not keeping time and had the board changed , still not keeping time
4 Suggested Answers
  • 11 Answers
SOURCE: need part number for a kenmore range clock/timer replacement
part #496225
Posted on Dec 05, 2007
SOURCE: Kenmore Range clock issue
That works, to change from military 24 hour to 12 hour format press and hold the clock button until it beeps and changes the displayed time, e.g. from 20:01 to 8:01. This worked on my Kenmore Elite Range. If you get the dreaded F1 error, you'll likely have to replace your clock timer board.
Posted on Mar 11, 2009
mastertec14797
  • 318 Answers
SOURCE: How do I fix control board clock that not display clock and some controls functions not work on a slide in range kenmore
Hello. I need the model number to help you accurately. The symptoms you describe point to a defective main control board or defective display board(depending on the model range you have). Some ranges have the touch panel and display all-in-one and others have separate boards--I need the model number to give you the exact part number(s).
Posted on Sep 13, 2015
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
Kenmore 790.9622 electric range - front right inner burner not heating
You have to use a voltmeter to make sure the element is getting voltage, if it is, then replace the element
Jun 10, 2009 | Kenmore 96222 / 96224 / 96229 Electric...
F-1 code keeps comming up on my Kenmore Gas Range
The information I found today says to replace the keypad or the clock assembly. The ket pad is around $60.00 and the clock I can sell for $245.00. This will give an idea on cost.
May 13, 2009 | Sears 61301 Gas Kitchen Range
Fuse from with old kenmore range
There is an internal component in the clock that is probably responsible for the noise not much can be done other than changing the clock. Also try tightening all screws on the clock. good luck
Dec 19, 2008 | Kenmore 96012 / 96014 / 96019 Electric...
Kenmore electric Range model 635040L0
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Sep 24, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Kenmore range code f1 e2
F1-E2 - UL A/D Error(s) - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Aug 05, 2008 | Kenmore 72002 / 72004 Kitchen Range
Apr 02, 2008 | Kitchen Ranges
Kenmore 96222 / 96224 / 96229 Electric Kitchen Range Logo
32 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
