Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HCP-4752 convergence adjustments
Dear Person: I was in the TV repair bussiness for OVER 45 yrs & left it a year ago because HDTV , plasma & flat screens went WAAAY over my head...A friend sent me a Samsung HCP-4752W with a convergence problem..The red horiz was bowed down at the top only of the pix..One of the STK-392-010 IC's was bad...I replaced BOTH IC's with Sanyo IC's , NOT generics...ALL the resistors associated with both IC's checked OK...After I replaced both IC's , I noticed that the red vertical on the left side is a bit out of convergence...The rest of the pix seems OK...It just needs some touch-ups..FYI:..Self focus is working but it does NOT correct it..Neither myself nor my customer are willing to pay for a complete service manual just to accomplish this...I have mucho experience with factory service menus...What I need is the FULL factory service menu for convergence AND step by step adjustment procedure...Your help WILL be GREATLY appreciated...Thank you VERY much in advance...RonM
  • sjones4779 Nov 06, 2008
    I have the same issue also. Just replaced the Sub PWR & DEF board, and changed the coolant in the Blue CRT. Now I cannot find the FULL service menu settings. I need to dim the blue some....I may end up having to change the coolant in R & G also.
Get new set
Posted on Jun 02, 2009
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My set is 10 yrs old. In the upper left and lower
Try adjusting the convergence. If it won't move see below- red IC in particular
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 18, 2009 | Sony KP-43HT20 43" Rear Projection...
No tv picture
my less than 2 yrs. old hardly used Samsung plasma is turning off automatically for no reason within 10m minutes of watching. What could be the problem??????????
Mar 16, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Feb 25, 2009 | Samsung HC-P4741W 47" Rear Projection...
Samsung hcp-4752w
With power on, press Mute-1-8-3. That will get you into convergence mode. 1 sets factory default convergence. Avoid pressing 2 - it resets everything. 3 restores the last saved settings, 4 switches among fine adjust, line adjust and grid move. 7,8,9 - select R,G,B. The three keys below those turn RBG on/off.
Self-focus to save the settings. S-Mode to exit.
It can be a REAL headache, but take your time, and you'll get it done.
As an after thought....if you have a need to manually adjust the convergence, you probably have something wrong - unless you've just replaced parts and are doing the initial convergence.
Dec 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence issues?
most likely the convergence board.
Ordered complete convergence board, ask samsung for part number Convergence AMP PCB $108.44, from www.samsungparts.com
or could send it in to ptscorp.com for repair.
Dec 23, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence problem with Toshiba TV 42H83
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Aug 04, 2007 | Toshiba 42H83 42" Rear Projection...
Samsung 46in.
This is a Plasma TV set, there is no convergence adjustments on this set. the convergence adjustments are for tube type projection TV sets. You could have a few problems with your TV. You could have a bad color whell assembly, a bad light engine assy. or a problem with the main board. This is not a set a that some who is not trained on plasma TV sets should attempt to troubleshoot and or repair. depending on how old this set is, it may still be under warranty. if it is not, call out only a Samsung authorized servicer, as they will have the boards and proper tools to service this TV. Good Luck
Mar 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
550 people viewed this question
Henry  Thomas
Henry Thomas
