Question about JVC DRMH20 DVD Recorder
The display flashes 'LOADING' when finalising after 20 seconds.
Sir,
My JVC DRMH20 DVD Recorder display flashes the message 'LOADING' 20 seconds after the 'finalise' function has started. If componant replacement is required that is not a problem.
Many thanks
JS
  • 1 more comment
  • jgarmin Oct 20, 2008
    Sir,
    My JVC DRMH20 DVD Recorder display flashes the message 'LOADING' 20 seconds after the 'finalise' function has started. If componant replacement is required that is not a problem. Unpluged the unit for 20 minutes as you suggested with no success. The unit is 2 years old.
    Many thanks
    JS
  • jgarmin Oct 21, 2008
    Sir,
    My JVC DRMH20 DVD Recorder display flashes the message 'LOADING' 20 seconds after the 'finalise' function has started. If componant replacement is required that is not a problem. Unpluged the unit for 20 minutes as you suggested with no success. Also cleaned the optical reader, no success. The unit is 2 years old.
    Many thanks
    JS
    Sir,
    My JVC DRMH20 DVD Recorder display flashes the message 'LOADING' 20 seconds after the 'finalise' function has started. If componant replacement is required that is not a problem. Unpluged the unit for 20 minutes as you suggested with no success. Also cleaned the optical reader, no success. The unit is 2 years old.Which IC'S do i need to replace?
    Many thanks
    JS
    Sergeant:
    Champion:
  • 435 Answers
I am not sure if this will work in your case but worth a try.
- Switch the unit off and unplug from wall
- Open the casing on dvd recorder,
- Disconnect hard drive power and data IDE cable
- Reconnect cables and put casing back and try.
This might work now ...
Posted on Oct 21, 2008
  • 507 Answers
This is a well-documented fault. In the USA power lobbiests got JVC to recall the units and fix the problem. The fault is a small component that was wrongly specified - when it reaches a set 'maximum' temperature is fails and causes a protection shut down. Over time it fails to allow start up. It is worth finding your nearest JVC approved repairer (if it is out of warranty) and have the recorder repaired.
Here's the official help as in the good old USA -
A limited number of units of certain models of DVD recorders (Models-DR-MV1S, DR-M10S, DR-MH30S, DRMX1S, SR-MV30U) have experienced the symptoms described. While manually resetting the unit, as set forth in the question, restores normal operation, the symptoms may reappear. JVC has identified the cause of these symptoms and will make the necessary adjustments to affected units to eliminate the likelihood that the symptoms reappear. Adjustments will be made free of charge at JVC Factory Service Centers. Click the Factory Service Center link at top left of this page to obtain your nearest location. Please call 1-800-252-5722 and select option 4-3 if you have any questions regarding this process.
Presumably the UK JVC Centres will also carry out these free of charge ! NO SUCH LUCK! We are 'Rip-off' Britain - as always.
Here - for your further understanding - what happens in the UK:
Repairs to JVC products are carried out through the JVC dealer network. All JVC dealers are aware of the technical support that is available from the JVC Service and Engineering Division if required. Unfortunately JVC UK are unable to quote the repair rates for JVC independent service dealers. We recommend that you call these dealers in order that they can communicate their repair charges to you.
The JVC Service Centre in the DE postcode area is: Trade Services, Holbrook Rd, Belper. Tel: 01773 822073
Repair Dealer : Relliance, Babbington Lane, Derby. Tel: 01332 363488
Posted on Oct 20, 2008
    Scholar:
  • 84 Answers
You have to replace sum IC's of your dvd the ic's are related to time out settings for your dvd
Posted on Oct 19, 2008
    Brigadier General:
  • 3,614 Answers
Clean the optical reader.just try a optical head cleaning on the unit
    Genius:
  • 1,550 Answers
How old is your unit ?
After Loading message what are you getting ? any error message .
Try this unplug the unit for 20 minutes and plug the unit after that time this will remove the error .
  • SAM ANDERSON Oct 20, 2008
    The PSU board is right on top after removing the
    lid, and you'll probably see one or two of the capacitors have a
    bulging top. Change the lot as caps have a limited life. I am providing you the list of capacitors you have to look at .
    Secondary board Electrolytic Caps:
    Medium secondaries (blue) -
    16v 470uf 105c x 4 (C5331, C5318, C5319, C5321) 519 – 3977 x 4
    Large (brown) -
    16v 1200uf 105c x 1 526 - 1288
    10v 1500uf 105c x 2 449 – 0924 x 2
    10v 1200uf 105c x 1 526 - 1121
    10v 1000uf 105c x 1 520 - 1422
    Medium (brown) –
    16v 680uf 105c x 1 526 – 1402 (1418?)
    Small (brown) –
    6.3v 220uf 105c x 2 449 – 0839 x 2
    Small (blue) -
    50v 18uf 85c x 1 228 – 6880
    10v 100uf 85c x 6 520 - 1393 x 6
    100v 4.7uf 105c x 1 519 - 4510
    16v 100uf 105c x 3 519 – 3949 x 3
    16v 10uf 105c x 1 414 - 9008
    50v 22uf 105c x 4 519 – 4295 x 4
    50v 2.2uf 105c x 1 519 - 4245
LOADING LIGHT KEEPS FLAshing
If 'Loading' flashes for more than one minute, try a reset by unplugging from its power source for 10 seconds than plug it back in and turn it on.
More likely this recorder needs to be serviced.You should contact JVC this issue usually qualifies for a free service program, which means JVC will flip the bill on repairing it if it is shipped to JVC's Service factory and their techs determine it qualifies.
Oct 04, 2009 | JVC DR-MV1S DVD Recorder/VCR
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
Loading is flashing and can not do anything
my machine just has loading displaying in a flashing mode
Jan 29, 2009 | JVC DRMH20 DVD Recorder
Cd recording on jvc dr-mh20
You can record sound on DVDs (up to 8x -R), CD data discs cannot be recorded on your machine.
Dec 18, 2008 | JVC DRMH20 DVD Recorder
Loading problem
kinda heath robinson affair this one.
If you buy a usb to IDE adapter, they come with a 5v & 12v power supply.You need to open the unit and connect this to the dvd drive's power.
You'll know it's working if you hear hard drive activity.
The recorder will power down, then just power on and away you go !!
alternativly (not tested) get a ide power cable splitter, but the current might be too much
Jul 11, 2008 | JVC DRMH20 DVD Recorder
Loading problem
There´s good material on this topic on FixYa. Look for it under JVC DRMH20.
JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Mar 12, 2008 | Televison & Video
Unlocking code
I know of three people who tried doing this with discs purchased off EBay - and trashed their machines. Not recommended.
Dec 17, 2007 | JVC DRMH20 DVD Recorder
JVC DRM10 DVD Recorder Problem
This unit is showing and error message "Disc Not Recordable" with a maxell DVD-R 1-16 Speed Single Sided Recordable DVD.
Nov 09, 2007 | JVC DRM10 DVD Recorder
Hard Drive not responding
sounds like a bad hard drive or a software problem and if im not mistaking this kinda thing has to be done "in-house"(at the factory) Try this info Hope it helps!! Good Luck Main support number(800) 252-5722 Email support proinfo@jvc.com
Apr 08, 2006 | JVC DRMH20 DVD Recorder
JVC DRMH20 DVD Recorder Logo
248 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
