Computers & Internet Logo
Posted on Jan 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Today when i was installing windows 7 and the setup was just started i found an error- 'cd/dvd driver missing'... i have already format the c drive so System can not even boot up... please help me out of this trouble.. thank you!
Anonymous
Level 3:
  • Samsung Master 32,281 Answers
  • Posted on Jan 22, 2012
Anonymous
Samsung Master
Level 3:
Answers
32281
Questions
Helped
7911886
Points
102259
Reseat the CD/DVD drive. Reboot and go into the BIOS setting to see if the CD/DVD drive is detected.
If not then the CD/DVD drive is faulty and needs to be replaced.
1helpful
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Hi im trying to install windows 7 on my aspire 4715z, as im starting to start the instalation when an error appear "a required cd/dvd drive device is missing. if you have a driver floppy disk, cd,...
Hi there !
Your windows operating dvd installer is damage. It just the CD/DVDROM drive cannot read your DVD installer because it have too many scatches in your DVD. Just get new OS dvd installer and repair your windows 7 operating system or reinstall the operating system.
2helpful
I have recently purchased a new HDD (I now have 2 Hitachi P7K500 HDDs) and built it into my system. I have first formatted the HDD I already had, then configured my BIOS for use of RAID 0. My mobo (MSI...
1. If you are just setting up your computer to have an a regular HDD and Backup HDD, i would think you should be able to set that up by booting onto your computer regularly, go to start, then into My Computer and right clicking on the HDD you want to set as Raid 1.
But if just want that other HDD for Space on your computer, all you had to do was plug it in and there you go... extra space.
Now if your installing windows 7 on the other drive i would find that pointless because you already have it on your first drive unless your putting 2 operating systems onto your computer.
Hope this helps.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
