I have an HP 7310 all in one fax. The auto feeder quit working. How do I fix?
    Genius:
  • 2,120 Answers
Open the feeder up and check for obstructions.
Posted on Oct 16, 2008
Top paper feeder roller rotates but does not draw in the paper
There is no replacement rollers available so, printer needs to be replaced.
Apr 08, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Using Fax and will not pull in papers to be faxed
You may have selected to fax from glass or you may have a piece of paper on the glass. If your placing the paper in the document feeder and it is still not rolling in. Check to see that there isn't anything jamming the feeder. The thing that activates the feeder and tells the printer to fax or scan from feeder is a small spring latch that sits internally at the top part of the cover and when ever paper is fed through it, it will engage the feeder. This small spring latch can easily come off or disengage from the unit especially if you have recently moved the printer. Check to see if it's a spring problem. If it is all you have to do is place it in place and all should work as normal. Be very careful not to force anything and gentle with any other component that you may encounter while looking, they can easily brake off.
Hope this works for you!
Jan 21, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Auto reject faxes
Hi There
Simple answer No ! best way is to get your telco supplier to block the number that is spamming your fax m/c
Regards ~Al "alstech"
May 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How to set up fax number on my 7310 all-in-one.
According to the HP manual for this unit:
1. Verify that your HP all-in-one is set to answer fax calls automatically. (Press the Auto Answer button so the light is on.)
2. Press Setup.
3. Press 5, and then press 1.This displays the Advanced Fax Setup menu and then selects Answer Ring Pattern.
4. Press the down arrow key to highlight an option, and then press OK. When the phone rings with the ring pattern assigned to your fax phone line, the HP all-in-one answers the call and receives the fax.
You can download the manual from HP here if you've misplaced yours and need more setup information.
Apr 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Auto Document Feeder sqeeks and groans
the problem is the cluthch that controls the feed roller, do not overdrive the the roller in the opposite direction it will damaged the mechanical clutch inside.
that is the one making the sound.
Jun 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310
Sounds like there is something going on with the paper sensor flag that resides in the top cover of the automatic document feeder. Need to make sure it is moving freely. It is spring loaded so it should move freely and spring back in to place. Sounds like your may be sticking in the up position after a few sheets. When the ADF lid is down these sensor flags should go in to holes in the bottom of the ADF. Hope this helps..
Inkworks
May 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure
You can copy, but not scan or fax from the flatbed...
You can copy, but not scan or fax from the feeder...
Am I reading this correctly?
Oct 18, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder
Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
k24674
