Cannot play sound on my computer
When i try to play or record a sound on my computer a message pops up and says 'another application is recording audio stop recording with this other application and then try to record with this sound recorder again.'
    Genius:
  • 1,605 Answers
Take a look at your quick launch tool bar (the little arrow nex to the clock.) run your pointer over each one of them and see if any of the audio device is running. if so, right click on theicon and exit or close.
please rate the answer if that solved your problem
thank you
Posted on Oct 16, 2008
Audio recording for toshiba nb520
Troubleshoot: Unless you already did this, go to Device Manager and check the properties of all other hardware involved.
Mar 14, 2013 | Toshiba NB520-11W
How do I record screen with freeware?
I used to record Skyrim gameplay with Fraps, it's a rather good one and its basic version is free.
I can also recommend the following open source tool to record screen. It's free of charge and there are no troubles occuring while using it.
May 31, 2012 | Computers & Internet
I have a mxl 990 microphone and its hooked up to a Pro tools LE 8 Mbox Mini . when im recording on protools or any other software with this mic, i hear a static/popping sound and it records the popping...
Try increasing the latency. Depending on your computer, it may not be able to handle low latency levels. Latency is a measure of the delay between the time you make a sound and the time the computer records that sound. With the Mbox mini, the unit for latency is the number of samples the driver collects before sending them to an application as input. Lower latency can make recording easier and more accurate, but not all computer systems can operate at the lowest latencies without introducing noise. Open the Mbox mini dialog and select the latency tab. experiment with higher latency levels and see if it goes away. somervta_0.jpgThis is what the dialogue might look like. another solution would be to try a different DAW. I had the same problem with my Fast Track Pro in ProToolsand it worked fin on Reaper, Garageband and Logic.
Jan 17, 2011 | M-Audio MXL 990/991 Recording Mic Duo and...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Cant playback video files
after i got full hard desk on my sony HD (HDR-XR520) any vide i record i cant copy it and it doesn't appear on my computer and then the files on the camera when i play them they don't ply and i found a message said: No applicable files available, so please how can solve this problem? or it's an industrial bad side with this camera??
Apr 28, 2010 | Sony Handycam HDR-XR520 High Definition...
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Selecting a custom recording.
I was told that the day and night settings in the local applications must be the same. It is in your night call routing table that you need to place the extension in order for the system to know which recording to play when. Then, your system will play the application when it is set in night mode. Hint: When you place the extension in the call routing tables make sure the extension is placed ABOVE the +ALL CALLS line, if applicable, and your ring-in-destination is set to your appropriate application recording. I hope this helps.
j
Dec 15, 2008 | Inter-Tel Axxess Corded Phone
Computer internal dvd player/recorder won't record. it will play, though. I also have an external player/recorder that won't record either but plays. The internal dvd burner gets a message no recordable...
if both are malfunctioning it indicates an application error. Uninstall then defrag and cleanup your harddisk from system tools, then re-install your burning softeware. If your O/S is an old installation it might be time to try a fresh install. Also, I would clean both drive lenses with isopropyl and cotton buds just to make sure that is not the issue. My feeling is that you need to reinstall your O/S(windows)
Oct 07, 2008 | Computers & Internet
Files will not transfer to PC or play when attached to PC
Hi have you installed the correct software for your device
Dec 06, 2007 | Olympus WS-100 Digital Voice Recorder
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
