Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Kenmore 15751- dish water leaks out as it goes in
As soon as the water goes in to the Kenmore 15751, it leaks out below, just above the motor.
How do you hook water supply up
Posted on Oct 22, 2008
What causes leak between filter and filter housing on kenmore elite model 40141003010.
Hello Emile;
My name is Peter. I am a retired field service refrigeration technician.
I assume your changed the below component:
25693704-zbtre13rzitqz5mqvrpod1im-1-0.jpg At the ends of the plastic tubing are plastic push pull connectors. If the tubing is not properly seated and locked into the connector you will have a leak.
You may also have a crack in the connecting tubing from the water tank.
When you use your water dispenser, the water dispenser solenoid valve allows 65 PSI water pressure into the plastic tubing line, where if you have a bad connector or a crack in the line will cause a leak.
The is a plastic cap on the top of the above component.
1.) Put your fingers behind the above component where the tubing goes into the plastic mounting head. More often than not you can get bad parts
2.) Have someone push the water dispenser lever. Observe if water is running down the plastic tubing or if your fingers are getting wet.
May 13, 2015 | Kenmore Refrigerators
Kenmore ultra wash dishwasher leaks from the bottom of the door edge
You electic water valve is sticking open, they get sand etc in there, and can not close, and will not shut the water input off. Do you have city water, or your own well water? Very common problem with well water, sand will clog the return of the water valve from shuttin off the water. Easy to check if you can shut the power off, and water off. dis-assemble the water inlet valve( first thing the input warter goes to)
Dec 19, 2012 | Kenmore Dishwashers
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 | Dishwashers
Leaking on the bottom
www.applianceaid.com/dish.html
www.apwagner.ca/index.php?main_page=page&id.
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Service manual, above that are DOY help links. http://www.repairclinic.com/Dishwasher-Repair-Help
May 04, 2010 | Kenmore 17459 Free-standing Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water leaking from back right side
look at the back of the refrigerator , you will notice a hose that goes down on a try above the motor compressor, try to clean it or inserting a very tin long object that can able to reach the lenght of the hose, this cause a clogging reason for the water after frost to overflow
Oct 31, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaks above motor when the machine is turn on.
The seal around the pump / motor assembly may be bad. The seal can be purchased seperate from the pump.
Sep 05, 2009 | Dishwashers
Water leaking into refrigerator & under vegetable bins
Generally the condensing water leak in a dish above motor (compressor), wen evaporate from the heat generated here...
You can try to locate the hose here and blowing with something to 'clean' the clogged hose.
Jun 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
Leaking water
Your pump is leaking. it is attached to the front of the motor. Very common. Pump retails around $60.
Part number is 3363394
May 19, 2009 | Kenmore Washing Machines
Dishwasher
I have a kenmore dishwasher (about 10 year old) it won't turn on. It just buzzed when set to wash. What can I do?
May 15, 2008 | Dishwashers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
78 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
