Question about Hotpoint Washing Machines
HOTPOINT AQUARIUS 1000 DELUXE 9538
THE DOOR IS JAMMED IS THERE A MANUAL WAY OF OPENING IT
    President:
  • 1,462 Answers
No manual way.
check machine has drained fully - if not door will not open. in this case, put drain hose down at floor level in a shallow dish to drain
otherwise
disconnect from mains.take top off. feel down front of machine where door latch is and you should be able to feel door peg thro the interlock. pry to one side with thumb nail to open (this is quite difficult)
or
break door handle off and lever door peg with a small screwdriver
Posted on Oct 16, 2008
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Garage door opener just hums, won't go up or down
Either the motor has seized or the door itself has jammed. Unlock the manual release (Usually a cord or lever hanging down 1/2 way along the track) Sometimes if its a side mounted motor, the lever will be at the side of the motor .Pull the cord or move the lever, and the door should be able to be opened manually. If its stuck then you will need to check the tracks and rollers on the door and door frames to see whats jamming it. Repair or replace as required. If the door comes up freely, that will prove its not the door jamming.Try leaving the door in the manual position and turn the motor on. The door wont open or close itself when in the manual position, but the motor should run. If it still hums, I would say the motor has seized. Sometimes, its cheaper to get a new opener / motor complete assembly rather than a replacement motor on its own. Check with the manufacturer and or supplier of the door opener to confirm.
Aug 26, 2014 | Building Materials
Ford f350 rear door jammed
You will need to remove the door panel and manually trigger the latch to open the door.
Nov 08, 2012 | Cars & Trucks
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Power sliding door will not open at all manually with remote or with door locks tried to remove iod fuse and sliding door fuse but still dont open thanks
either something jammed in track/lock-- or actuator rod broke or disconnected from lock --need to remove interior door panel to get to lock release and latch check all rods and clips for damage or missing repair or replace as necessary u can manually unlock the door at latch if something was jammed or stuck in latch
Nov 26, 2009 | 2007 Dodge Caravan SXT Minivan New Cars
Both manual sliding doors on my Toyota Sienna will not open
Check out this youtube video for taking off the interior door panel and resetting. https://www.youtube.com/watch?v=MkC2OiOiE_U
Apr 09, 2017 | 2000 Toyota Sienna
Volvo s80 rear door jam
you have bad door lock motor
Apr 20, 2009 | 2000 Volvo S80
Get code C0b61 on Minolta 4000 copier
Check the exit bins mite be jammed. Service manual is Bin movement. Check mvement of all bins open close finiher door and reset front door
Mar 04, 2009 | Konica Minolta DiALTA Di200 Copier
Washing Machines Logo
560 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
