Question about NetGear CG814M Wireless Cable Modem Gateway Router
Wireless feature defective?
I bought this modem off of ebay in hopes of using it as a modem/router combination unit. After MANY hours of tech support from Netgear and my ISP, I have determined that the wireless portion of this device is not working properly. The modem aspect is fine.
Is there a way to disable the wireless signal that my home computers are still detecting from this device? My router that I am now using (a Linksys) is not working at full capacity and someone has mentioned to me that some sort of interference from my Netgear router could be the cause of this?? Personally, I don't know. I'm just looking for some suggestions. Thanks.
    Master:
  • 538 Answers
Interference is a maybe..
as to disabling the router..not possible..all you can do is make the signal a manual mode on your computers and ignore it..
sorry.
Posted on Oct 16, 2008
Was having problems w/ internet connection. Brighthouse tech just left. Replaced modem and fixed a loose wire at box outside. Still won't hook to wireless and says that it is probably my router
If you have a separate modem and router turn both off and reboot only modem till all lights up the reboot router till all lights up in that order sounds simple communication problem between router and modem. If router modem combo unit disconnect either dsl or cable from router/modem leave diconnected for a short time then reconnect and reboot till all lights up. Hope this helps.
Sep 01, 2012 | EnGenius ESR-1221 EXT Router
I was having connection problems to the internet. A verizon tech came out and said my modem was old and out dated. He replaced it with a new modem but I don't know how to get my linksys wireless router...
Most of the modems that Verizon (depending which market you are in) techs are using are combination modem/routers, so you may not need to use your Linksys wireless router anymore. Typically the default SSID (wireless signal name) and password (if there is one) is printed on a label attached to the router. You can use this default info if you'd like or reconfigure the router using the following steps. Log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default username and password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
I have bought a wireless ADSL modem, Dlink DSL 2640u , How can I install and use it for another laptop? I want to use it without wire. Thanks
all wireless devices must be allowed in the router by either MAC address or by name. This is accomplished by logging into to the router and setting up the device in with the wireless setup feature in your router. The router will not allow the device to connect without permissions.
Aug 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
Dec 16, 2009 | Belkin (F5D6230-3) Wireless Router
Concerting TV to PC
to my understanding,LCD can only be connected as monitor ,not to become a computer itself.if ever it can be use as one, you'll need all the basic of the computer accessories.wireless modem can be use as long as there is a slot for or the unit is compatible for a wireless connection.check first if there is a socket for keyboards and everything before buying.since it can be connected only by vga cable, i assume that it is for monitor use only,unless you want to use two monitors at the same time.
May 14, 2009 | Televison & Video
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Connect Wii via wireless router
The modems wireless feature is always on. For some reason entering the security code wasn't working so I turned off the security feature and it worked fine. After the wii downloaded updates I turned on the security to the most secure settings and everything continued to work. I guess maybe the wii update fixed the issue or I just needed to change to the most secure setting.
Jan 02, 2009 | 2wire (1000-000057-000) Modem
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
I have a belkin n wireless router keeps freezing
First step of solution would be performing Reset. Press and hold the reset button about 30 seconds and release. Check again. If you need customized settings just type 192.168.2.1 in your browser and get into settings.
If issue persist please post for further troubleshooting.
Good Luck
Jan 24, 2008 | Belkin (F5D7231-4) Wireless Router
Router/modem?
Your device is a combination Cabal Modem and Wireless Router with a fairly limited security screening profile. While it is doubtful that the problem is the OS on your notebook, it could easily be the wireless network card in your notebook that is the problem.
In this instance replacing the unit is probably the best way to go, as there are much better units available for much less money and in addition you will have full access to the configuration of the router and its security and connection settings.
To replace this device with one new device simply be certain to get a Cabal Router/Modem with Wireless Access.
Nov 14, 2007 | Arris SURFboard SBG900 Wireless Router...
NetGear CG814M Wireless Cable Modem Gateway Router Logo
70 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
