Question about Maytag Washing Machines
Both mounting studs for the auto washer motor show signs of excessive wear and will not hold tension on the drive belt pulley. Will you tell me the nearest center to fayetteville NC where they will replace the two studs? thanks
    Genius:
  • 1,239 Answers
HI DONT WORRY READ THIS
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Posted on Oct 16, 2008
How to put serpentine belt back on
There should be a label under the hood that shows the pattern and You Tube has lots of videos by brand and year that show the actual process. Process if done correctly is to hold the spring loaded auto belt tension unit back (mine you just insert the head of a 3/8 ratchet and pull it back, move the belt into position and back the tension off, smooth on belt to smooth on pulley and grooved part of belt to groved parts on the other pulley.
Try You Tube first and you will get the idea, easier with a second person to help, I recently did mine alone outside with a temperature of 14 degrees.
If the belt came off for no reason inspect the tension unit.
Dec 04, 2012 | 2001 Ford Escort ZX2
Hi The washer will not spin at all. Thanks
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a washer to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
or try to follow this instruction
1. Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
2. Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
3. Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
4. Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
5. Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
May this help your problem.
Thanks good day!
Sep 12, 2011 | Kenmore 44102 Front Load Washer
It does not spin - error
Hi
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
May 03, 2011 | LG Washing Machines
How to change a belt on a Whirlpool washer model LA555OXTWO
I am not exactly sure on your machine, several places called it a direct drive unit but here are some directions I have found also.
1) Turn off water. Disconnect electrical supply and water hoses.
2) Remove agitator and cap from machine ( this is not always possible as the agitator gets frozen on the shaft, it just makes the job a little easier )
3) Lay machine on it's front. Protect front of the unit from scratches. Do not leave it over night on it's front as some oil will leak out the breather hole on top of the transmission.
4) Remove rear service panel
5) Loosen both nuts holding the motor mounting bracket in the slotted base plate holes. (see figure 1)
6) Rotate the motor to the right to relieve the belt tension and remove belt from motor pulley
7) After belt is removed from motor pulley, rotate motor to the left as far as possible to assure cam bar clearance.
8) The spin cam bar must be advanced to the spin position. Push up on the spin control solenoid plunger and rotate the main drive pulley until the cam bar advances to the spin position.
9) Remove the brake yoke spring from the gear case cover and yok. (see figure 2)
10) Remove completely the 3 support braces attached to the gear case and base plate. (see figure 3)
11) Remove the 2 pump mounting bolts. The pump hoses do not have to be disturbed. (see figure 3)
12) Remove the gear case mounting stud which has the spacer. remove spacer (see figure 2). Loosen the remaining 2 gear case mounting studs approximately 7 turns. (see figure 3).
13) Remove yoke retainer from yoke support. (see figure 2 for the types of yoke retainer).
14) The gear case can now be pulled down so that the belt can be slipped out between the top of of the clutch shaft and the clutch yoke. (see figure 4) and then through the space beneath the short stud; drop the belt from around the gear case.
15) Reverse the procedure in steps 15 & 13 to install the new belt.
16) Replace the pump making certain the pump lever is engaged in the notch in the agitator cam bar before securing the pump to the gear case ( see figure 5).
17) Grasp the bottom loop of the yoke spring with a pair of pliers and engage the spring with the hole in the upper gear case cover (see figure 2).
18) Replace spacer in short gear case mounting stud. Tighten the 3 gearcase mounting bolts ( finger tight only ). Next, set the machine upright and tighten the gear case mounting bolts securely. This procedure will allow the superstructure to properly align itself with the center post bearing.
19) Lay the machine on it's front to mount the 3 support braces to the gearcase baseplate. Tighten the bolts securely.
20) To adjust the belt tension properly, position the belt over the pulleys. Insert a hammer handle or some other lever between the motor mounting brackets. Rotate the motor to the left as far as it will go. Tighten the nuts holding the motor mounting bracket. Check the tension of the belt, it should deflect about 1/2 inch. (see figure 1).
21) Set machine upright. Reinstall the agitator, agitator cap, service panel, water hoses and connect electrical supply.
Mar 07, 2011 | Whirlpool Washing Machines
How To Repair a Washing Machine That Won't Spin?
Instructions: 1)Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced. 2)Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place. 3)Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley. 4)Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness. 5)Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
thank you and hope this helps
Feb 09, 2011 | LG WFT1071TP Top Load Washer
2003 chevy suburban 1500 i replace my tensioner pulley and belt for my a/c compressor and now my tensioner is rocking back and forth and the truck idels hard when the a/c or heat is on
The tensioner is not set or aligned properly.
Rocked back and forth  this means the pivot bushing has worn down.
Tensioner Arm Misalignment
This may appear as metal-to-metal contact between
the arm and spring housing, and will be indicated by
shiny, smooth streaks or gouges in the metal.
Misalignment also is likely if the arm can be vertically
rocked back and forth. This means the pivot
Idler Bearing Wear
With the engine off and the belt removed, manually
rotate the tensioner pulley. Noise or resistance
when turning the pulley could indicate bearing
failure. Check for play in the bearing by rocking the
pulley. It should only pitch very slightly. If noise,
resistance or excessive play is found, replace the
pulley.
Excessive Tensioner Arm Movement
With the engine running, observe the back and forth
sway of the tensioner arm. If it exceeds 1/2” of
movement, or moves continually, the damping
system has failed. This movement can reduce the
life of the tensioner, belt and component bearings.
The tensioner should be replaced.
Improper Belt Tracking
With the engine running, inspect the belt and tensioner pulley. If the belt
is not properly tracking in the center of the pulley, the tensioner could be misaligned. This also can be a sign of a bent bracket or misaligned components. Check the drive components and repair if necessary.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 07, 2010 | Heating & Cooling
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Dependable Care M# LAT9416AAE will not spin. The tub is hard to turn.
It sounds as if the floating motor mount is no longer floating or the 2 springs inside of that floating / gliding mount are not working correctly. There are also 4 hard rubber clear washers that are part of the gliding mount. If any one of the 4 of those washers has broken the motor does not glide properly and will not tighten the belt properly for the spin cycle to work. Make sure the unit is unplugged reach underneath the left front corner and feel for a 2 V belt groved pulley. First push the pulley inward 45 deg from the corner and let it go.... If it is working properly it should automatically tension the belt. If is sticks in position the either the springs or washer have failed. This is not an expensive repair. IF you call for a repairman make sure he checks the condition of the tub drive belt. The motor has been placing undue wear on the drive belt due to it being loose.
Jan 06, 2010 | Maytag MAV3905AWW Dependable Clean Top...
Have a 92 pathfinder the belt squeel which then causes a lack of power why is that the case?
HI, There are only two reasons for this issue. The most common will be a worn, or damaged drive belt. This will cause slippage, in return, decreasing the normal power output of your vehicle. The second issue will be improper tension within the belts structure. You can adjust the tension by unscrewing the pivot and mounting bolts on the alternator. Using a wooden hammer handle or broomstick (or even your hand if you're strong enough), move the alternator one way or the other until the tension is within acceptable limits.
Inspect the belts for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will generally start at the inner edge of the belt and run outward. Replace the belt at the first sign of cracking or if the glazing is severe. By placing your thumb midway between the two pulleys, it should be possible to depress the belt 1 / 4 - 1 / 2 in. (6-13mm). If any of the belts, or belt can be depressed more than this, or cannot be depressed this much, adjust the tension. Inadequate tension will result in slippage or wear, while excessive tension will damage pulley bearings and cause belts to fray and crack.
NOTE_ Check the condition of the drive belts, and check the belt tension at least every 30,000 miles (48,000 km) or every 24 months. If tension is not an issue, and the belts show signs of ware, they should be replaced. Tension on the power steering pump belt is adjusted by means of an idler pulley.(on most models)
Nov 06, 2009 | 1992 Nissan Pathfinder
Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Oct 13, 2009 | Haier HLP21E Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
