Question about Car Audio & Video
Kenwood krc 391 ipod query
Hi, I have a kenwood krc 391 with 6 cd changer. I am wanting to install my ipod in my car but am not sure if this is possible with this stereo. Anybody tell me if its possible and if so which cable or cables i need?
Many thanks. Chris
lobsterman72
  • 91 Answers
SOURCE: Kenwood KRC-2001
That's for a cd changer.
Posted on Jul 08, 2008
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
SOURCE: Kenwood KDC-C717 - E-99 error
There is probably a jammed disc or disc holder. It cant eject the cartridge because the unit cant put the disc back into the cartridge to the left.
Took me a about 20 mins gentle persuasion after removing the plastic front (carefully depress the little plastic clips on the edges and (again, gently, lever the front off) and removing the metal case - half a dozen screws each side and remove the bottom. The top stays fixed to the workings. I could then get into the gap between the top case and workings but be careful not to pull the unit from the rubber antishock mountings etc. and remove the problem disc.
I removed the plastic fascia which surrounds the magazine hole too, not sure if it was necessary..!
Again - be careful not to be rough with it, you dont want to snap the plastic clips, etc and also check the horizontal/vertical adjusters are back on in the correct position if they come off.
Posted on May 16, 2009
  • 1348 Answers
SOURCE: Does a Kenwood KRC 278 R have RCA inputs?
the rca are outputs.
get a fm modulator.they sound good and are so simple to use.
Posted on May 28, 2009
asktate
  • 15 Answers
SOURCE: Kenwood KRC-794 car stereo
Here is the owners manual:
"http://www.payloadz.com/go/sip?id=889718"
Posted on Jun 12, 2009
Tuner to cd changer
try disconnecting power to the changer for a few hours and then plug it back in.
Mar 30, 2010 | Kenwood KRC-394 Cassette Player
Do you know where i can get a connector for the back of my krc-391 from!! regards jeff
I believe you can get ahold of kenwood or visit their website www.kenwood.com, They should have what you need or can direct you on where to go. Hope this helps
Nov 02, 2009 | Kenwood KRC-391 Cassette Player
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
Kenwood KDC-C662 6-Disc CD Changer - Error 'T99'
Hi....
Just accumulated dust can cause issues with the reader pickup
I'm not sure what T99 means but if you want to spend $35-90 to fix it,
it would be worth it.
Jan 06, 2009 | Kenwood KDC-C662 6-Disc CD Changer
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Ipod
On the Kenwood models that are within about 6 or 7 years old or newer, there is an iPod adapter for the head units that plugs into the CD Changer port on the back of the radio. Kenwood makes an adapter (KCA-IP500) that gives direct control and charging through the radio and several companies make aux input adapters for Kenwood radios that will connect to the iPod's headphone jack.
Sep 21, 2008 | Kenwood KDC-3024 CD Player
KRC-3008 KENWOOD
The "Reset" button on Model# KRC-207S is located between the"ATT" (attenuator) and the "1" button. It is a tiny hole. Insert the end of a pen or pencil into the hole and hold for a few seconds and the unit will reset itself. Hope this helps...
Sep 03, 2008 | Kenwood KRC-207S
Kenwood KRC-2001
Jul 08, 2008 | Car Audio & Video
Kenwood KRC-394 Cassette Stereo with CD CHanger
I have the same problem all of a sudden...it only shows as AUX when on CD mode.
The manual says to change the O-N switch to the 'N' side...however I dont know wherer the )-N switch is?!
Jan 29, 2008 | Kenwood KRC-394 Cassette Player
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
