Question about Black & Decker Leaf Hog Blower Bv4000
Leaf hog won't vacuum up the leaves/ blower does work
We tried using our leaf blower this year and the blower part of the machine works but it will not vacuum up any leaves? what are we doing wrong?
  • owgii Nov 03, 2008
    Mine is a Craftsman blower/vacuum. It does exactly the same thing blows but does not vacuum. . Any ideas would help.
    Thanks.
  • odachimaster Nov 08, 2008
    alright who has the answer to this
4 Suggested Answers
  • 8 Answers
SOURCE: B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
Posted on Nov 11, 2008
boscia
  • 163 Answers
SOURCE: zipper is really stuck
sometimes dirt and debree can get stuck in there, try saturating it with a strong penetrating oil like PB Blaster, available at your local auto parts store, and let it soak in for about an hour and use a pair of pliers to get a good grip.
Posted on Nov 29, 2008
SOURCE: The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Posted on Jun 17, 2009
citizensirhc
  • 19 Answers
SOURCE: My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
But not the type 2. Even though the failure described for the type 1 is exactly what I found in the type 2.
Posted on Dec 01, 2011
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Nov 18, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Where do i switch theLEAF HOG FROM VACUUM TO BLOWER
Remove vaccuum tube. Allow the access door for the vacuum tube to shut all the way. Attatch the blower tube where you had the collection back for the vaccuum attatched. That is it.
Feb 01, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I can not get the Leaf Hog to swtich from vacumn to blower. Any suggestions?
it does not "switch"
The air intake becomes the vacuum with an attachment. The "blower tube" is then the vacuum exhaust.
the motor does not change directions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
Black and Decker leaf hog, worked fine last use.
I posted this solution on another similar thread, but it may pertain here.
Jun 10, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Zipper is really stuck
Nov 23, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Nov 11, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Black & Decker Leaf Hog Blower Bv4000 Logo
201 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
